Harddisk showing ECC Error?
MadsRC
My daily status reports have begun notifying me of this:
Checking status of 3ware RAID controllers:
Controller c0:
Unit  UnitType  Status        %RCmpl  %V/I/M  Stripe  Size(GB)  Cache  AVrfy
u0    JBOD      OK            -      -      -      1863.02  Ri    OFF
u1    JBOD      OK            -      -      -      1863.02  Ri    OFF
u2    JBOD      OK            -      -      -      1863.02  Ri    OFF
u3    JBOD      OK            -      -      -      1863.02  Ri    OFF
u4    JBOD      OK            -      -      -      1863.02  Ri    OFF
u5    JBOD      OK            -      -      -      1863.02  Ri    OFF
VPort Status        Unit Size      Type  Phy Encl-Slot    Model
p0    OK            u0  1.82 TB  SATA  0  -            WDC WD2002FYPS-02W3
p1    OK            u1  1.82 TB  SATA  1  -            WDC WD2002FYPS-01U1
p2    OK            u2  1.82 TB  SATA  2  -            WDC WD2002FYPS-01U1
p3    OK            u3  1.82 TB  SATA  3  -            WDC WD2002FYPS-01U1
p4    ECC-ERROR      u4  1.82 TB  SATA  4  -            WDC WD2002FYPS-02W3
p5    OK            u5  1.82 TB  SATA  5  -            WDC WD2002FYPS-01U1
But it also contains this:
Checking status of zfs pools:
NAME  SIZE  ALLOC  FREE    CAP  DEDUP  HEALTH  ALTROOT
vol1  10.9T  1.52T  9.35T    14%  1.00x  ONLINE  /mnt
all pools are healthy
And I get this from the terminal:
[root@freenas ~]# zpool status
  pool: vol1
state: ONLINE
status: The pool is formatted using a legacy on-disk format.  The pool can
        still be used, but some features are unavailable.
action: Upgrade the pool using 'zpool upgrade'.  Once this is done, the
        pool will no longer be accessible on software that does not support feature
        flags.
  scan: scrub repaired 0 in 1h59m with 0 errors on Thu Nov 14 01:59:25 2013
        NAME                                            STATE    READ WRITE CKSUM
        vol1                                            ONLINE      0    0    0
          raidz2-0                                      ONLINE      0    0    0
            gptid/95c26382-f2b7-11e2-b96a-0025900055f4  ONLINE      0    0    0
            gptid/972b1579-f2b7-11e2-b96a-0025900055f4  ONLINE      0    0    0
            gptid/97db458f-f2b7-11e2-b96a-0025900055f4  ONLINE      0    0    0
            gptid/988db300-f2b7-11e2-b96a-0025900055f4  ONLINE      0    0    0
            gptid/992f1bc8-f2b7-11e2-b96a-0025900055f4  ONLINE      0    0    0
            gptid/99e0953d-f2b7-11e2-b96a-0025900055f4  ONLINE      0    0    0
errors: No known data errors
So too me it looks like the zpool is okay, but I still got that feeling in the bakc of my head that something is up.
I am thinking I should replace the disk (Just need to verify the steps first...) - What do you guys say? Is the disk dying (It still under warranty as it's a WD Black disk)?
Please post if you need me to run a few other commands.
warri
Do you see any problematic values in the SMART attributes of the disk?
