Hard drive not detected
Joao
Hi, i am trying to build a FreeNas, but when boot the hard drives are not found.
On WebGUI i am not not able to create volume, because not hard drives were found.
Hardware
Acer - M3201 - AMD Phenom X3
3 Gb RAM
03 - 320Gb WD
01 - 320Gb Seagate
01 - 500Gb Seagate.
1 Gbps Network
Software:
Freenas 9.2.1 installed in a 4 Gb USB
Troblueshoot already done.
All drives are detected - BIOS
Changed cables
Changed sata port between drives.
Changed BIOS to AHCI
Changed BIOS to IDE
Update bios
I need help, i am stuck and i don,t know what to do...
Tks
Joao
ahcich1: is 00000002 cs 00000000 ss 00000000 rs 00000001 tfd 50 serr 00000000 cmd 00046017
(aprobe1:ahcich1:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
(aprobe1:ahcich1:0:0:0): CAM status: Command timeout
(aprobe1:ahcich1:0:0:0): Error 5, Retry was blocked
run_interrupt_driven_hooks: still waiting after 60 seconds for xpt_config
ahcich2: Timeout on slot 0 port 0
ahcich2: is 00000002 cs 00000000 ss 00000000 rs 00000001 tfd 50 serr 00000000 cmd 00046017
(aprobe2:ahcich2:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
(aprobe2:ahcich2:0:0:0): CAM status: Command timeout
(aprobe2:ahcich2:0:0:0): Error 5, Retry was blocked
ahcich0: Timeout on slot 0 port 0
ahcich0: is 00000002 cs 00000000 ss 00000000 rs 00000001 tfd 50 serr 00000000 cmd 00046017
(aprobe0:ahcich0:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
(aprobe0:ahcich0:0:0:0): CAM status: Command timeout
(aprobe0:ahcich0:0:0:0): Error 5, Retry was blocked
ahcich1: Timeout on slot 0 port 0
joeschmuck
Old Man
First your system does not meet the minimum specs for RAM and I'm sure you have less available for the software but aside from that I'm certain you are having a MB compatibility issue. If you plan to pursue this use ACHI, not IDE during troubleshooting. And if you don't have any luck here, you might try NAS4Free or an earlier version of of FreeNAS like version 8.3.2 to see if that works.
