D3m0nicSoul
- Jan 28, 2017
Hello All,
Received an error on one of my drives stating "Device /dev/ada0, Self-Test Log error count increased from 0 to 1. I searched around the forum and saw that you should look at certain lines but they all seem to be 0. Can someone please look at the below output and let me know if you see anything suspicious? The drive is under warranty but I'm not sure if this is a false positive. Any help is greatly appreciated!
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68N32N0
Serial Number: WD-WC
LU WWN Device Id: 5 0014ee 210103d60
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Apr 2 22:24:39 2019 EDT
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 113) The previous self-test completed having
the read element of the test failed.
data collection: (43680) seconds.
Auto Offline data collection on/off supp ort.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 463) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_ FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 212 164 021 Pre-fail Always - 4400
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 18
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 094 094 000 Old_age Always - 4748
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 18
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 10
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 12
194 Temperature_Celsius 0x0022 113 104 000 Old_age Always - 37
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
Num Test_Description Status Remaining LifeTime(hours) LBA _of_first_error
# 1 Extended offline Completed: read failure 10% 4717 280 3373640
# 2 Short offline Completed without error 00% 4589 -
# 3 Short offline Completed without error 00% 4421 -
# 4 Short offline Completed without error 00% 4253 -
# 5 Short offline Completed without error 00% 4087 -
# 6 Extended offline Completed without error 00% 3976 -
# 7 Short offline Completed without error 00% 3919 -
# 8 Short offline Completed without error 00% 3752 -
# 9 Short offline Completed without error 00% 3584 -
#10 Short offline Completed without error 00% 3417 -
#11 Extended offline Completed without error 00% 3306 -
#12 Short offline Completed without error 00% 3249 -
#13 Short offline Completed without error 00% 3081 -
#14 Short offline Completed without error 00% 2913 -
#15 Short offline Completed without error 00% 2745 -
#16 Short offline Completed without error 00% 2578 -
#17 Extended offline Completed without error 00% 2563 -
#18 Short offline Completed without error 00% 2410 -
#19 Short offline Completed without error 00% 2242 -
#20 Short offline Completed without error 00% 2074 -
#21 Short offline Completed without error 00% 1906 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
