Alex_Patrio
- Jan 15, 2020
Introduction
Transmission Web Control is a custom web UI. The project began in Google Code. Welcome to give me any feedback or submit a Pull Request.
Support Transmission Version
How to install
- Transmission 2.40 and above (RPC version: 14 and above)
- A browser which supports HTML5. (Chrome 15.0.874,Firefox 8.0.1,IE 9.0.8112,Opera 11.52 etc.)
- Add torrent files or URLs
- Drag-and-drop to add torrent files
- Modify Transmission settings online (Download folder, Speed limit, Port, etc.)
- Pause / resume / recheck selected or all torrents
- View the current torrents status (Files, Peers, Trackers etc.)
- View Statistics (Cumulative/Current)
- Pagination
- Set files priority
- Change the torrent download directory
- Trackers list
- Multi-language support. Supported-languages: Click Me.
- Add support for Synology NAS Download Station; By - @hitechbeijing
- Support data folder display in the navigation bar.
- Support "user label" feature, you can use it to classify torrent.
- Automatically matches data directory. What's this?
How to install
- Before sending commands to the console or via the web interface, check the name of your pool
- Keeping the original web interface
mv /mnt/[NAME OF YOUR POOL]/iocage/jails/transmission/root/usr/local/share/transmission/web/index.html /mnt/[NAME OF YOUR POOL]/iocage/jails/transmission/root/usr/local/share/transmission/web/index.original.html- Download the latest version of transmission-web-control
wget https://github.com/ronggang/transmission-web-control/archive/v1.6.0-beta2.tar.gz- Unpack the archive
tar -xzf v1.6.0-beta2.tar.gz -C /mnt/[NAME OF YOUR POOL]/iocage/jails/transmission/root/usr/local/share/transmission/web/- Run the installation script
bash /mnt/[NAME OF YOUR POOL]/iocage/jails/transmission/root/usr/local/share/transmission/web/transmission-web-control-1.6.0-beta2/release/install-tr-control.sh- After starting the script: press the "1" key
- Waiting for the installation to finish
- Restart your jail
root@freenas[~]# mv /mnt/FreeNAS_Config/iocage/jails/transmission/root/usr/local/share/transmission/web/index.html /mnt/FreeNAS_Config/iocage/jails/transmission/root/usr/local/share/transmission/web/index.original.html
root@freenas[~]# wget https://github.com/ronggang/transmission-web-control/archive/v1.6.0-beta2.tar.gz
--2020-05-02 00:50:15-- https://github.com/ronggang/transmission-web-control/archive/v1.6.0-beta2.tar.gz
Resolving github.com (github.com)... 140.82.118.4
Connecting to github.com (github.com)|140.82.118.4|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://codeload.github.com/ronggang/transmission-web-control/tar.gz/v1.6.0-beta2 [following]
--2020-05-02 00:50:15-- https://codeload.github.com/ronggang/transmission-web-control/tar.gz/v1.6.0-beta2
Resolving codeload.github.com (codeload.github.com)... 140.82.113.10
Connecting to codeload.github.com (codeload.github.com)|140.82.113.10|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/x-gzip]
Saving to: ‘v1.6.0-beta2.tar.gz’
v1.6.0-beta2.tar.gz [ <=> ] 1.03M 676KB/s in 1.6s
2020-05-02 00:50:17 (676 KB/s) - ‘v1.6.0-beta2.tar.gz’ saved [1079605]
root@freenas[~]# tar -xzf v1.6.0-beta2.tar.gz -C /mnt/FreeNAS_Config/iocage/jails/transmission/root/usr/local/share/transmission/web/
root@freenas[~]# bash /mnt/FreeNAS_Config/iocage/jails/transmission/root/usr/local/share/transmission/web/transmission-web-control-1.6.0-beta2/release/install-tr-control.sh
Welcome to the Transmission Web Control Installation Script.
Official help documentation: https://github.com/ronggang/transmission-web-control/wiki
Installation script version: 1.2.2-beta
1. Install the latest release.
2. Install the specified version.
3. Revert to the official UI.
4. Re-download the installation script.
5. Check if Transmission is started.
6. Input the Transmission Web directory.
9. Installing from 'master' Repository.
0. Exit the installation;
Please enter the corresponding number: 1
<< 2020-05-02 00:51:20 >> == BEGIN ==
<< 2020-05-02 00:51:20 >> Transmission Web Path: /mnt/FreeNAS_Config/iocage/jails/transmission/root/usr/local/share/transmission//web
<< 2020-05-02 00:51:20 >> You are using the specified version to install, version: 1.6.0-beta2
<< 2020-05-02 00:51:20 >> Attempting to specify version: 1.6.0-beta2
<< 2020-05-02 00:51:20 >> Transmission Web Control Is Downloading...
--2020-05-02 00:51:20-- https://github.com/ronggang/transmission-web-control/archive/v1.6.0-beta2.tar.gz
--2020-05-02 00:51:20-- https://codeload.github.com/ronggang/transmission-web-control/tar.gz/v1.6.0-beta2
v1.6.0-beta2.tar.gz [ <=> ] 1.03M 490KB/s in 2.2s
2020-05-02 00:51:23 (490 KB/s) - ‘v1.6.0-beta2.tar.gz’ saved [1079605]
<< 2020-05-02 00:51:23 >> Download completed, ready to install...
<< 2020-05-02 00:51:23 >> Extracting installation package...
<< 2020-05-02 00:51:23 >> Copying installation package...
<< 2020-05-02 00:51:23 >> Setting permissions, It takes about one minute ...
<< 2020-05-02 00:51:23 >> Transmission Web Control Installation Completed!
<< 2020-05-02 00:51:23 >> Cleaning up the installation package...
<< 2020-05-02 00:51:23 >> Installation completed. Installation problems see:https://github.com/ronggang/transmission-web-control/wiki
<< 2020-05-02 00:51:23 >> == END ==
root@freenas[~]#
