Rilo Ravestein
- Mar 6, 2014
Of course you have to adjust all settings in the files to your specific needs.Is this only in the script or both the ipfw rules
Your VPN service should provide you with the OpenVPN config file. A link is provide in the OP. I don't use PIA, so I don't know how else to get it if the link doesn't work.My config file is Pia so I'm not sure what the address us
Looks like you did not copy the correct config file provided by PIA to the correct place. OpenVPN needs to know what remote server IP to connect with.When I open it it does not have a IP address it has
Client
Dev tun
Proto udp
Remote server address
Nobind
Persist-key
Persist-tun
Location for ca.crt
Tls-client
Remote-very
Auth-user-pass
Comp-lzo
Verb 1
Reneg-sec 0
Crl-verify location
Auth user location
Please also read the other thread i suggested in an earlier post. I suggested it for a good reason; it will give you some extra info on how things work, for OpenVPN as well as the firewall rules.
