Guessed BIOS device 0x80 not found by probes
D
DeletedUser88470
Guest
Eventually I received my HW, but I am struggling installing FreeNAS.
I used Rufus to create a bootable USB stik in Windows with the latest version of FreeNAS 11.2 BETA 2.
I am quite certain that it is a BIOS fault, so I updated to the latest version BIOS on my X11SSH-F.
It doesn't quite get past this error message, and hangs.
I would like to install it on a 128GB M.2 disk i have installed.
Could someone advise?
D
DeletedUser88470
Guest
Did anyone else have problems installing it? I have checked the checksum, installed it on 3 different USB sticks, and tried all the different USB ports - I have also tried both UEFI and legacy without luck. I have also disconnected all drived including the M.2 ssd, still getting the same message.
Does anyone else have the same board, but without any installation problems?
D
DeletedUser88470
Guest
OK, even more confusion - the Freenas 11.1 STORAGE ONLY CONFIGURATIONS is now working but not the 11.2 BETA 2 STORAGE, PLUGINS, AND VIRTUALIZATION...?
What is the difference?
Is there another version I should get instead?
gpsguy
Active Member
Don't worry about the descriptions.
FreeNAS 11.1-U6 is the latest stable version. FreeNAS 11.2-Beta2 is a beta version for the next release. It's final release isn't expected for at least 2 months.
If you'd like to read about what's new in 11.2, you can download a copy of the 11.2 documenation via a link in my signature. See the section regarding :new features in 11.2".
To save you the time, the 11.2 Beta release notes include this:
  • The boot loader has changed from GRUB to the native FreeBSD boot loader. This should resolve several issues that some users experienced with GRUB. GRUB was introduced as a temporary solution until the FreeBSD boot loader had full support for boot environments, which it now has.
D
DeletedUser88470
Guest
I currently have the 11.1 RELEASE installed which I expect being somewhat older than the U6 - Should I upgrade to U6 instead or do a clean install?
What is the difference between the RELEASE versions and the U.. Versions?
Sent from my LON-L29 using Tapatalk
