rmavillarica
- Oct 9, 2017
Greetings from the Philippines!
I have done a bunch of reading and learning in this forum and hope these are not silly questions.
I am currently using RAID1 with Ubuntu on some old Atom hardware and a couple of 3TB WD Red drives. I am beginning to run out of space and thought I would bite the bullet to protect data and my wife's photos (about 300GB per year). I would like to use some of my old hardware. I currently have:
2 pcs - WD Red 3TB - One of them has an unusually high Load Cycle Count - 100k+, the other has nine (9!).
1 pc - WD Green 3TB - I will wdidle all of the Green drives.
1 pc - WD Green 2TB
2 pcs - WD Green 1TB
3 pcs - Seagate 5TB USB - I think these are the shingle type drives, so I don't intend to use these.
2 pcs - 32 Sandisk ReadyCache SSD drives
2 pcs - Sandisk Cruzer Fit 8GB USB flash drives
I would like to buy 8TB or 10TB WD Red drives to make up the balance, plus an extra one as a cold spare. The 8/10 decision will be based on Camelcamelcamel price monitoring in the next month, and is slightly coupled with the X11SSM-F/X11SSL-CF decision: do I use the SSDs as mirrors, or save the SATA ports and use a couple of USBs? Maybe it would be better to spend the extra $85 and SAS breakout cables on the X11SSL-CF motherboard?
If mirrored USB flash drives are safe, I am thinking of running a 6+2 (10TB and USB boot drives) RAIDZ2 with a Supermicro X11SSM-F motherboard or an 8+2 (8TB or 10TB) RAIDZ2 with a Supermicro X11SSL-CF motherboard. In the case of the X11SSL-CF, I would use the mirrored SSD drives to boot.
If I run 6+2 drives, the calculator says I should have 4.296 TiB usable initially. If I run 8+2 drives, I should have 5.728 TiB usable. I have a bunch of media on the three 5TB drives I can migrate as capacity grows.
Can I start with one stick of 16GB ECC RAM and add more as I replace the smaller hard drives with larger hard drives that should be cheaper in the future?
Thank you!
Martin
1 pc - WD Green 2TB
Thank you!
Martin
