Do I understand correctly the situation with GPU passtrough via Truenas Scale.
You can run Scale with no gpu installed to your system.
If you insert 1 gpu to your system, that does not change anything. You are not able to passthrough this GPU.
So, if you want GPU passthrough to your VM, you'll have to add 2 gpu's to your system..? to passthrough 1 GPU?
