Github repository for FreeNAS scripts, including disk burnin and rsync support
MrToddsFriends
Documentation Browser
Using FreeNAS 11.1
I downloaded and tried the disk-burnin.sh script and am running into an error. When I run the script, I get: Syntax error: newline unexpected (expecting word)
From the documentation in
https://github.com/Spearfoot/disk-burnin-and-testing
The only required command-line argument is the device specifier, e.g.:
./disk-burnin.sh sda
...will run the burn-in test on device /dev/sda
VintageGold
Thanks for pointing that out. I get the same error when I tried again and substituted "sda" for "ada0" based on the disk name I can see when I look in the FreeNAS console or run the command
camcontrol devlist
Am I looking in the wrong place?
MrToddsFriends
camcontrol devlist
If you are still getting the same error ("Syntax error: newline unexpected (expecting word)") when running ./disk-burnin.sh ada0 with the first argument ada0 being the device to be chosen for the burnin test then there's something weird going on. camcontrol devlist is of course not a bad way to get access to device names. Hopefully @Spearfoot has some time to look at it.
While I'm running 11.1-U2 right now, it has been a while since I ran Spearfoot's disk burnin script for the last time, so I can't say for sure that it is supposed to run as-is on 11.1.
Spearfoot
He of the long foot
@VintageGold : I suspect you may have used a Windows text editor to edit disk-burnin.sh at some point... DOS or Windows text editors will often replace UNIX newlines with DOS/OS2/Windows newlines (Carriage Return/Line Feed pairs), which makes UNIX shell scripts fail with errors much like you're seeing.
Try downloading a fresh, unmodified copy of the script and then edit it in a shell session on your FreeNAS system, using either vi or nano -- both text editors are available on FreeNAS. If you must use a Windows text editor, use one that lets you select how newlines are encoded and use the UNIX setting when saving the file.
Regarding the devices on your particular server... you can use the smartctl --scan command to scan it and show you a list. Here's the result from one of my servers:
root@bandit:~ # smartctl --scan
/dev/cd0 -d atacam # /dev/cd0, ATA device
/dev/da0 -d scsi # /dev/da0, SCSI device
/dev/da1 -d scsi # /dev/da1, SCSI device
/dev/da2 -d scsi # /dev/da2, SCSI device
/dev/da3 -d scsi # /dev/da3, SCSI device
/dev/da4 -d scsi # /dev/da4, SCSI device
/dev/da5 -d scsi # /dev/da5, SCSI device
/dev/da6 -d scsi # /dev/da6, SCSI device
/dev/da7 -d scsi # /dev/da7, SCSI device
/dev/da8 -d scsi # /dev/da8, SCSI device
/dev/da9 -d scsi # /dev/da9, SCSI device
/dev/da10 -d scsi # /dev/da10, SCSI device
/dev/da11 -d scsi # /dev/da11, SCSI device
/dev/da12 -d scsi # /dev/da12, SCSI device
/dev/da13 -d scsi # /dev/da13, SCSI device
/dev/da14 -d scsi # /dev/da14, SCSI device
/dev/da15 -d scsi # /dev/da15, SCSI device
Note that all of my HDDs are attached to an HBA, so they have dax filenames. If you have HDDs attached to SATA ports they'll typically show up with adax filenames.
Good luck!
Chris Moore
Using FreeNAS 11.1
Here are my steps. I based my commands on the ones jgreco included here for his HDD burn-in script: https://forums.freenas.org/index.php?threads/building-burn-in-and-testing-your-freenas-system.17750/
cd /tmp
fetch https://github.com/Spearfoot/disk-burnin-and-testing/blob/master/disk-burnin.sh
chmod +x disk-burnin.sh
./disk-burnin.sh
Is this because I'm using 11.1 and the code needs an update?
You are fetching the wrong file. I used your command to fetch it and I ended up with the html document.
VintageGold
You are fetching the wrong file. I used your command to fetch it and I ended up with an html document.
Hmm, I tried it again with my original code. Here's what I entered and the output. I modified the last line to include the target device, as instructed by MrToddsFriends.
root@freenas:~ # cd /tmp
root@freenas:/tmp # fetch https://github.com/Spearfoot/disk-burnin-and-testing/blob/master/disk-burnin.sh
fetch: https://github.com/Spearfoot/disk-burnin-and-testing/blob/master/disk-burnin.sh: size of remote file is not known
disk-burnin.sh										 132 kB  465 kBps 00m00s
root@freenas:/tmp # chmod +x disk-burnin.sh
root@freenas:/tmp # ./disk-burnin.sh ada0
./disk-burnin.sh: 7: Syntax error: newline unexpected (expecting word)
As @Chris Moore stated, you're fetching the wrong file; you need to get the raw file instead. Use this fetch statement:
fetch https://raw.githubusercontent.com/Spearfoot/disk-burnin-and-testing/master/disk-burnin.sh
Chris Moore
Don't forget that it is in dry run mode until you change the variable from 1 to 0.
# Set Dry_Run to a non-zero value to test out the script without actually
# running any tests: set it to zero when you are ready to burn-in disks.
Dry_Run=1
VintageGold
@Jurgen Segaert, thank you! That's exactly what I needed. I looked back what @Chris Moore said and opened it with nano and saw it was the wrong file. Also, thank you Chris for mentioning the variable about the dry run so I didn't have to post back here that it didn't run right! @danb35, thanks for teaching me a new way to see the file w/out using nano.
Chris Moore
One last thing. Now that I have this working, is the disk-burnin.sh script considered a replacement for jgreco's solnet-array-test-v2.sh script provided as part of his Building, Burn-In, and Testing your FreeNAS system guide, or will they effectively serve the same purpose, which is to find issues with a HDD that would warrant a replacement?
They have different purposes.
solnet-array-test-v2.sh is a non destructive test, as I understand it, that is designed to determine the performance of all the disks in a group. The burn-in utility is designed to write to all locations of the drive in a data destructive test that is intended to stress the drive and uncover defects.
Stux
yes. you can run solnet over a live zfs array.
droeders
First off - thanks for creating and posting these scripts. I use the SMART report script daily on several servers.
I noticed a bug in the SMART test age checks within smart_report.sh, but it's under some weird circumstances. It's very repeatable, so I wanted to report it.
I have an Intel SSD which doesn't support SMART test logging. It returns the following for "smartctl -l selftest":
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-RELEASE-p9 amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
No self-tests have been logged. [To run self-tests, use: smartctl -t]
I have the testAgeWarn variable set to 7 days. When my drive age went over 1000 days (24k+ hours), the test age warning no longer adds the "?" symbol for the drive name. I've tested it some, and it's definitely on the 1000 day boundary. For some reason, you also need testAgeWarn set to a value greater than 1 in order to see the error.
I patched it on my systems with the following change, but I clearly don't fully understand why it's broken. Some sort of string vs integer comparison problem?
-- smart_report.sh 2018-04-08 12:48:32.447970000 -0500
+++ /tmp/smart_report.sh 2018-04-08 13:49:50.265942000 -0500
@@ -92,7 +92,7 @@
/High_Fly_Writes/{hiFlyWr=$10}
/Command_Timeout/{cmdTimeout=$10}
END {
- testAge=sprintf("%.0f", (onHours - lastTestHours) / 24);
+ testAge=(onHours - lastTestHours) / 24;
if (temp > tempCrit || reAlloc > sectorsCrit || pending > sectorsCrit || offlineUnc > sectorsCrit)
device=device " " critSymbol;
else if (temp > tempWarn || reAlloc > 0 || pending > 0 || offlineUnc > 0 || testAge > testAgeWarn)
@@ -105,7 +105,7 @@
if (hiFlyWr == "") hiFlyWr="N/A";
if (cmdTimeout == "") cmdTimeout="N/A";
- printf "|%-6s|%-18s| %s |%5s|%5s|%5s|%7s|%7s|%8s|%6s|%10s|%6s|%7s|%4s|\n",
+ printf "|%-6s|%-18s| %s |%5s|%5s|%5s|%7s|%7s|%8s|%6s|%10s|%6s|%7s|%4d|\n",
device, serial, temp, onHours, startStop, spinRetry, reAlloc, pending, offlineUnc,
seekErrors, totalSeeks, hiFlyWr, cmdTimeout, testAge;
Let me know if you have any questions.
Spearfoot
He of the long foot
@@ -92,7 +92,7 @@
END {
@@ -105,7 +105,7 @@
Are you certain that your Intel SSD doesn't support self-test logging? I'll be surprised if it doesn't.
Have you ever run any self-tests on the SSD? If not, please run a short test -- smartctl -t short /dev/??? -- specifying your SSD's device ID where I've put question marks. Then post the output of smartctl -l selftest /dev/??? in code tags.
droeders
I was surprised too, but this model definitely does not support logging. I've run both short and long tests in the past on two of these drives. On both drives, they show the percentage remaining as it's being tested, but never a record of the test in the logs. I just ran a short test again and got the same results.
Here's a link to the SSD:
https://ark.intel.com/products/56576/Intel-SSD-510-Series-120GB-2_5in-SATA-6Gbs-34nm-MLC
Spearfoot
He of the long foot
Astounding!
This means that the script simply won't be able to track the length of time since the last SMART test for this particular SSD, and thus won't be able to correctly display the 'warning' indicator character in the output.
devnullius
I tried to do:
git clone https://github.com/Spearfoot/FreeNAS-scripts.git, but I get the following error:
Failed to connect to github.com port 443: Operation timed out
When I google this, I see that it has to do with proxies - which I don't use? How to easily get those scripts to a folder on my NAS? :)
You can just download them to your client and upload them to the server in your preferred way.
