So yeah, I'm not entirely sure what the issue here is. I can transfer at ~110MB/s and then receive at ~110MB/s but the moment I try to transfer and receive simultaneously, my rate drops down to ~55MB/s each way over SMB. This also occurs when one client is transmitting and a different one is receiving files from my FreeNAS server at the same time.
I have already ruled out a Windows/desktop issue because I get ~112MB/s up and down simultaneously with a direct connection between my desktop and laptop. I also get similar speeds when my desktop and laptop are doing the same test when connected to my Cisco SG300-24P Switch which rules that out as well. My server is no slouch being a Supermicro X10SL7-F with an E3-1231 v3, 32GB of RAM, and dual Intel I210 NICs. Also to rule out disk IOPS issues, I setup my second NIC on a different subnet with a direct connection to the second NIC on my desktop. From there I sent files on one subnet and received files on the other, averaged ~105MB/s but suffered the same rate of ~55MB/s when doing a simultaneous transmit and receive exchange. I highly doubt it's a hardware limitation so it must be some sort of misconfiguration unless SMB on FreeNAS isn't the greatest but I think my last test ruled that out. What are you all's take on this situation? I have been unsuccessful in finding any posts anywhere that talk about this same exact issue that I am having when trying to transmit and receive files simultaneously on a singular connection. Any assistance would be greatly appreciated, if you need more information just let me know what you need, and thanks for your time!
