getting intel pro GT to work with 8.3.0
i have searched the forums but cant find anything
i want to upgrade the onboard NIC for obvious reasons
i have freenas 8.3.0 x32 it is using the em0 driver
is there anything else i need to do. i thought intel NICs were well supported
i can get old and slower NICs to work so im sure the problem is freenas
The extent of installing the card is "Is it plugged into the motherboad?"
If you are getting em0 then that is your Intel NIC. In fact, just minutes ago I plugged in my Intel GT card to a FreeNAS server and it came right up.
If yours isn't working then you should check your network settings.
thanks for testing a GT card for me at least thats one thing i can rule out.
i have three different brand new GT cards (two of them are OEM)
i have used an old NIC in the same PCI slot which works fine so i dont think the PCI slot is faulty
i have tried putting a GT card on DHCP and no luck
ive given the GT card a static IP outside of the pool and still not working
my motherboard is gigabyte mini-itx GA-D525TUD
the onboard LAN works fine (Realtek RTL8111E) with very similar IP and mask
i cannot ping freenas using a GT card
im getting desperate now - ive even tried booting it up with the storage drives taken out to see if the PSU is overloaded (180W)
any ideas how i can get it to work anyone have a clue what problem could be?
i'll try anything
I don't know what to say.. if it's not working I'd assume its a hardware problem/incompatibility. Some OEM cards only work with the same manufacturer's hardware. I can't say I've seen that with network cards, but its a possibility.
Honestly, since it's an Intel Atom, your Realtek will probably work fine. It's not exactly a high performing card, but it'll definitely be CPU limited from what I've seen of other people with Atoms on the forum.
im managing to get upto 100mb/s with a re0 and re1 so i cant complain
i never considered the processor to be the bottleneck
thanks for help
You should be getting better than that. Total throughput by people has been 200-400Mbit/sec if I remember correctly. Perhaps you have a 100Mb network switch?
jgreco
Resident Grinch
There's a reason that shift key is on your keyboard...
This is ambiguous.
If you had said "100MB/sec", that'd mean 100 megabytes per second, which would be respectable with a crummy network interface.
If you had said "100Mb/sec", that'd mean 100 megabits per second, which would be awful.
But "100mb/s" doesn't clearly mean either. Of course, some people will misuse the above terms anyways, so if you want to continue your shift-less (haha) existence, please consider writing "100mbits/sec" or "100mbytes/sec" and people will not have to puzzle out what you mean.
Technically jgreco is correct. There's been quite a few threads where people confuse mb and MB and Mb. Frankly, I used to want to castrate people that couldn't use the correct terms since they make a BIG difference. If my FreeNAS server copies at 100MB/sec that's a great speed. But at 100Mb/sec that's terrible and something is wrong.
"Mega" is represented by a capital M, not a lower case.
i am aware of this but it was obvious what i meant
whoops sorry jgreco
I am aware of this but it was obvious what i meant.
any sentence that begins with 'technically' contains inaccurate advice.
and thanks for the help
