I had a nice freenas system geli encrypted
Build :FreeNAS-11.1-U5
During a thunderstorm I wanted to shutdown the freenas. I wasn't sure of my geli key
I had my geli key and geli recovery in a dropbox.
I made a new recovery key but I stored it in the freenas encrypted and I lock the volume.
So I read that you can detach and re-import.
I detach (but with some error message timeout)
In the storage tab / volume / now I have "no entry has been found"
Import volume / step 1 of 2 encrypted ZFS volume: Yes decrypt disks / OK
Step 2 of 3 : Disk: I choose a disk
Encryption Key : I select the geli-2019.key
Passphrase : mypassphrase
And I get /[MiddlewareError: Unable to geli attach gptid/b4d452cd-fc7f-11e4-841d-0cc47a0d7e71: geli: Wrong key for gptid/b4d452cd-fc7f-11e4-841d-0cc47a0d7e71.
During my search I tried this :
zpool status --> which tell me that I have 1 data errors so I did
zpool status -xv
pool: freenas-boot
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 0 in 0 days 00:05:49 with 1 errors on Sun Mar 8 03:50:49 2020
NAME STATE READ WRITE CKSUM
freenas-boot DEGRADED 0 0 8
gptid/a0055ee5-fc64-11e4-b2a4-0cc47a0d7e71 DEGRADED 0 0 72 too many errors
freenas-boot/ROOT/11.1-U5@2016-09-20-01:17:20:/usr/local/lib/gcc47/libstdc++.a
I think I have /libstdc++.a problem before the geli mess...
How can I be sure that it's absolutely over?
What do I've to do
Thanks
zpool status -xv
pool: freenas-boot
state: DEGRADED
What do I've to do
Thanks
