Fusion-IO how to enable/compile drivers?
Nik
Hi all,
I wonder if there is just a tuneable variable that needs to be enabled or if I need to compile the drivers in order to get my Fusion-IO drive running. Currently all that is does is to show me a red LED :-(
I have the drivers 3.2.6-1212 for FreeBSD 9.0
If I need to compile the drivers, what is the easiest way to install the kernel sources?
Nik
D
dlavigne
Guest
Your best bet is to create a feature request at bugs.freenas.org and post the issue number here.
