Hi folks,
I am thinking about virtualization recently to include a pfSense "machine" at home. However, I do not know if it is feasible or not.
While there are people that support virtualized FreeNAS (e.g. link1, link2, link3, and even two books ), there are also people who does not (e.g. link1, link2). Hence, I am a bit confused :
1. will my current configuration will run proxmox + FreeNAS + pfsense?
2. is the migration of my current freenas config to virtualized FreeNAS feasible?
3. is it better to keep my actual FreeNAS as FreeNAS and add a pfsense on a "wreck"?
My current configuration is a HP N54L with 16GB ECC, 3x2TB WD Red in RaidZ, and a 8GB USB stick. Additionally, I have an IBM M1015 (not flashed), a 60GB SSD, an intel NIC, and an old noisy m-itx atom mobo.
My idea is to: dump the FreeNAS configuration; remove the USB stick and HDDs; install intel NIC; install the SSD and proxmox (or ESXi) onto it; create the pfsense VM and provide access to WAN and LAN; create the FreeNAS VM and provide access to LAN; mount the HDDs and provide them direct access from FreeNAS VM; restoring FreeNAS configuration;
If anything goes wrong, then restore USB stick :)
Do you think it could work?
Additionally, while FreeNAS requires 8Gb of RAM, + 1Gb * 1Tb in ZFS (i.e. 14Gb), pfSense requries 1Gb of RAM, and 8Gb to ProxMox, my N54L has 16Gb. Should I move on another configuration (e.g. DELL T130 with 32Gb and a core I3)? Or should I keep my N54L and use the oldy noisy atom as pfSense machine?
All the best,
Juspolo
P.S. I have 2 users.
All the best,
Juspolo
