BlakeNagel07
- Jan 4, 2016
Just posting to see what everyone thinks of my setup.
SYSTEM:
Case: Fractal Design Node 304 Black
PSU: EVGA 600W 80+
Mobo: Gigabyte H97N-WIFI
CPU: Intel Core i3-4170 @ 3.7GHz (4 cores)
RAM: 16GB DDR3 @ 1600MHz
Storage: 4 x 2TB WDred in RAID-Z
Boot: 2 x 16GB SanDisk Cruzer USB flash drives mirrored
Jails: Plex, Transmission/OpenVPN, Jackett, Sonarr, Radarr, nginx
Release: FreeNAS 11.2-U5
Over the 4 years I've had one drive get bad sectors that S.M.A.R.T. detected, WD replaced under warranty. Over the past month I started looking into pfSense to secure my network and adding that to my FreeNAS build running in a VM. I know that plenty of people will say that this isn't recommended but after implementing it last week I have had no issues. All system reporting still shows very little usage on CPU/Memory even when hitting it with multiple devices.
When incorporating pfSense I installed a Intel Quad Port NIC that gets passed through.
pfSense system
Runs on VM
Allocated 2 Cores
Allocated 4gb RAM
Quad Port NIC
---Runs the following services
OpenVPN (allows remote connection to home network)
ntopng (tracks network activity)
pfBlockerNG (whole home ad blocker)
Snort (detects network intrusion attempts)
I would like to start to upgrade my system but not sure if its necessary at the moment. (if it ain't broken, don't fix it)
If you were to change anything what would it be and why?
SYSTEM:
PSU: EVGA 600W 80+
pfSense system
Runs on VM
Allocated 2 Cores
Allocated 4gb RAM
Quad Port NIC
