Bulletproof
- Nov 17, 2012
I picked up a Synology DS1512+ (5 Bay Dual Ethernet) which works really well. I am able to saturate a single Ethernet while using RAID 6 and only WD 3TB Red Drives, coming from Raptor/WD Black only this seems surprisingly good. With nic aggregation, I'm able to get over 200MB/s consistently and about 105-116MB/s with a single operation.
I am finding somethings with the device that are bothering me. Most importantly lack of snapshots typically native to ZFS. The built in backup options are very basic and don't do a good job for my needs. You can root the box and customize it but I don't think there is an option to get snapshots or ZFS.
I used FreeNAS ages ago and I liked it, but it never seemed to perform all that well. It seems to have matured quite well over the years and ZFS is a very attractive option over just rolling a box and configuring everything from scratch.
I am looking for Windows, Mac, NFS/iSCSI (most likely just NFS).
I have five WD 3TB Red Drives I would want to use. Will I be able to get similar performance with FreeNAS & ZFS?
Any suggestions on a good small form factor 5+ bay hot swap box with cpu/memory. I really like the Synology form factor, and one of the reasons I didn't roll my own solution. But before I get too dependent on the box, I want to look into getting something with ZFS snapshots and better backups (encrypted rotating USB3/eSata external).
Thanks!
Thanks!
