FreeNAS with Dual CPU (only one work?-why)
Robert76
I have Intel dual CPU board and 2 Xenon CPUs...
I have noticed that after installing FreeNAS that power consumption dropped by half, it shows I have 64GB(what would suggest both CPUs are working as the configuration I have is that if motherboard does not see 1 of the CPUs, it will show only half of the available RAM)
Anyhow BIOS shows 2 CPUs are working, BMC Console as well, whole RAM is visible by FreenNAS but the power consumption dropped like only one of CPUs would work.
In FreeNAS I do not see in any place that I have 2 CPU-s.... should I?
What's up? is it normal?
styno
On my systems, FreeNAS 11 has much better power management (and less consumption) in comparison to 9/10. What OS are you comparing to?
Redcoat
My backup Dell system has dual functioning CPU's.
FreeNAS "System" "Information" shows:
Build FreeNAS-11.0-U4 (54848d13b)
Platform Intel(R) Xeon(R) CPU E5630 @ 2.53GHz
Memory 32721MB
Chris Moore
Robert76
No OS, just when I was switching on server and be only in BIOS, the power consumption was twice higher (around 189W) basically doing nothing, and now it consumes 123W during copying multimedia of 3TB from external network drive to FreeNAS share.... but when not copying or doing any other special action on FreeNAS it is showing between 90-100W....., so looks like FreeNAS will save my bill and use CPU power efficiently :) anyhow could show somewhere there are 2 CPUs and how busy they are.... ;-)
Chris Moore
Chris Moore
Chris Moore
It does list the cores during boot that should be in the log file.
tvsjr
SSH in and try:
dmidecode -t processor
That should identify the processors in use.
You can also run top, and hit "P" while it runs to show all processor stats. My box shows 32 CPUs - dual E5-2670s (8 cores each) with hyperthreading - 8*2*2=32.
Or just open up a shell somewhere and use
dmesg | grep FreeBSD/SMP
Should get something like
FreeBSD/SMP: Multiprocessor System Detected: 16 CPUs
FreeBSD/SMP: 2 package(s) x 4 core(s) x 2 hardware threads
