Freenas wbwd0: HEFRAS and EFER do not align message
tanik1
Hi, I recent had a problem with my cifs share getting an EA dos attribute message. And was trying to correct the problem. As I was doing so I saw this message in the log. I checked online and searched I saw a bunch of bug tracking reports but they were for older versions of freenas and im on 9.3 stable. But non really explained what it was. Is this message relating to the drives or some other hardware? I removed all my drives but still have that message. Something is not align nor can it be attached. Seeking for help. Thank you.
Error message:
Dec 31 18:30:08 freenas wbwd0: HEFRAS and EFER do not align: EFER 0x2e DevID 0xff DevRev 0xff CR26 0xff
Dec 31 18:30:08 freenas wbwd0: DevID 0xc5 DevRev 0x63, will not attach, please report this.
Z300M
Identical here except for the DevID and DevRev values.
D
dlavigne
Guest
That's the watchdog driver. I think those messages can be ignored. If you disagree, create a bug report at bugs.freenas.org and post the issue number here.
tanik1
is there a way to turn off watchdogd? cause it was never able to start on my server.
D
dlavigne
Guest
You can create a Tunable as follows:
Type: sysctl
Variable: watchdogd_enable
Value: NO
You may also have to turn it off in the BIOS.
tanik1
Thanks dlavigne, but i tried to add that to the tunables and it gave me this error code
  • Variable names must: 1. Start with a letter. 2. End with a letter or number. 3. Can contain a combination of alphanumeric characters, numbers, underscores, and/or periods.
And I never seen that option in the bios.
D
dlavigne
Guest
Please post a screenshot that shows what you typed in along with the error message.
tanik1
here is the picture. Its weird cause the name meets all the requirements right?
D
dlavigne
Guest
Looks like you've stumbled upon a bug. Please create a report at bugs.freenas.org that includes that screenshot and your version of STABLE and post the issue number here.
tanik1
Thought that was the same login as here, had to register to post bug. here is the ticket number Issue #7389.
