Earlier this year I was looking into building a FreeNAS machine, and then I discovered how much I'd be paying for the server. I also discovered PCI-E passthrough and so I decided to upgrade a few of the specs, and make a virtualized windows gaming machine to live alongside my virtualized FreeNAS. Long story short, I've setup the windows VM, and there are some unexpected quirks that make the experience annoying, so I'll be changing some stuff around.
I have 2 choices as I see it:
1. Install Windows as the primary OS, and then run FreeNAS as a VM
2. Build / buy a separate smaller machine (~$500) and setup FreeNAS on that.
My Machine:
CPU: E5-1650 v3
Memory: 64 GB
HD1: 500 GB SSD
HD2: 9 TB WD Red
My plan is to take the 9 TB HD, back-up all my family photos and videos on it, and setup crash plan pro as its backup. I don't need instant recovery or anything like that. If my hard drive goes bad, a week or 2 of my server being down isn't the end of the world. I just want to be able to guarantee I won't lose my data.
I'd like to stick with option 1 and virtualize FreeNAS (as my machine is plenty powerful, and I'd like to save the money). I found this post on virtualizing FreeNAS, and honestly it scares me a little. I'm comfortable doing things I have little knowledge of with computers (i.e. setting up pci-e passthrough), but I'm nervous about setting up the things they are talking about in that post as I have no knowledge of them, and setting them up improperly can mean data loss. It's also possible that these are all very easy configurations in the FreeNAS settings that I don't know about. How difficult will it be to get FreeNAS configured properly as a VM?
VirtualBox is probably what I'd use to virtualize FreeNAS on Windows (if there's something better you can recommend, I'll use it). How difficult will it be to get a proper setup running? Is there maybe a good guide that steps me through it?
Any advice is welcome!
My Machine:
CPU: E5-1650 v3
Memory: 64 GB
HD1: 500 GB SSD
HD2: 9 TB WD Red
