FreeNAS v11 - Can someone tell me what this error means/possible work around?
NASbox
I did a fresh install of FreeNAS v11 on an SSD, and then did the autoupdates to 11U3, and then restored my settings from v8.3.1.
To protect my data, I have left all my data disks disconnected.
I then swapped my motherboard (original was a G620-2 Cores/2 Threads, New MB is an i7-3770, 4 Cores, 8 Threads), added an LSI HBA and an Intel 2 port NIC card.
I then from the GUI changed the location of the database to the SSD boot volume. (It was set to TANK which is my main ZFS pool which is not attached, and may or may not contain a database anyway because it was created under 8.3.1)
I am getting the following error: (Multiple occurances, different CPUs-see complete log below if needed)
Sep 25 01:27:41 freenas collectd[3116]: aggregation plugin: Unable to read the current rate of "freenas.WORKGROUP/cpu-6/cpu-user".
Sep 25 01:27:41 freenas collectd[3116]: utils_vl_lookup: The user object callback failed with status 2.
Can someone tell me what this error means? Does it have any implications other than just dumping a bunch of crap into the logs?
It appears to be a bug that has been around for some time:
https://bugs.freenas.org/issues/23857
Just wondering if anyone has found a work around?
My guess is that it might be caused by cores being in a dormant (power saving) state - but that's just a guess.
My complete log is attached (log.txt) in case it's relevant (with Ser#s/MacADDRs redacted)
  • log.txt
NASbox
Is there a work around/way to suppress these messages? I'm getting so many that they are obscuring important information.
Even if I have to turn off some reporting, it's likely better than putting up with these messages.
Any assistance/suggestions much appreciated.
Oct 9 16:15:52 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-2/cpu-idle".
Oct 9 16:15:52 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
Oct 9 16:50:42 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-2/cpu-user".
Oct 9 16:50:42 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
Oct 9 17:10:42 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-3/cpu-user".
Oct 9 17:10:42 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
Oct 9 17:32:22 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-2/cpu-user".
Oct 9 17:32:22 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
Oct 9 17:53:52 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-3/cpu-user".
Oct 9 17:53:52 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
Oct 9 18:00:22 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-3/cpu-system".
Oct 9 18:00:22 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
Oct 9 18:03:12 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-3/cpu-user".
Oct 9 18:03:12 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
Oct 9 18:12:42 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-4/cpu-user".
Oct 9 18:12:42 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
Oct 9 18:17:32 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-4/cpu-user".
Oct 9 18:17:32 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
Oct 9 18:21:12 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-4/cpu-user".
Oct 9 18:21:12 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
Oct 9 18:27:22 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-3/cpu-user".
Oct 9 18:27:22 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
Oct 9 18:47:12 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-1/cpu-user".
Oct 9 18:47:12 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
Oct 9 19:05:42 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-0/cpu-user".
Oct 9 19:05:42 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
Oct 9 19:10:22 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-0/cpu-user".
Oct 9 19:10:22 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
Oct 9 19:24:22 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-3/cpu-user".
Oct 9 19:24:22 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
Oct 9 19:37:52 freenas collectd[3162]: aggregation plugin: Unable to read the current rate of "freenas.pvt/cpu-3/cpu-user".
Oct 9 19:37:52 freenas collectd[3162]: utils_vl_lookup: The user object callback failed with status 2.
