Hiya,
just upgraded my freenas server from 8.3 to 9.1 release.
Couldn't upgrade through the GUI so I just made a new USB drive and booted from that, uploaded my config worked like a charm.
Used the : /root/migrate_pluginjail.sh -D
command to upgrade my jail since I had an Ajaxplorer/Teamspeak/... installation on it.
when verifying if everything works i get something "weird":
<code>
Jail# sockstat
sockstat: struct xtcpcb size mismatch
sockstat: struct xinpcb size mismatch
USER COMMAND PID FD PROTO LOCAL ADDRESS FOREIGN ADDRESS
www-ajaxplorer php-fpm10980 0 stream/var/run/php-fpm-ajaxplorer.sock
www-ajaxplorer php-fpm10980 9 stream(not connected)
www-ajaxplorer php-fpm10979 0 stream/var/run/php-fpm-ajaxplorer.sock
www-ajaxplorer php-fpm10979 9 stream(not connected)
root php-fpm 10978 5 stream -> ??
root php-fpm 10978 7 stream -> ??
root php-fpm 10978 8 stream /var/run/php-fpm-ajaxplorer.sock
root php-fpm 10978 9 stream (not connected)
www nginx 10958 3 stream -> ??
www nginx 10958 10 stream -> ??
www nginx 10957 3 stream -> ??
www nginx 10957 8 stream -> ??
root nginx 10956 3 stream -> ??
root nginx 10956 8 stream -> ??
root nginx 10956 9 stream -> ??
root nginx 10956 10 stream -> ??
Jail#
</code>
when googling i found on freebsd forums something about my kernel being out of sync with the world?
http://forums.freebsd.org/showthread.php?t=4077 (for reference)
Havn't done anything yet, kinda worried atm so if anyone could come relax me i'd appreciate it ^^
<code>
Jail# sockstat
Jail#
</code>
