FreeNAS up & running, just a teeny hitch ...
NexusB
My router is only 10/100mbit, and I'd rather just directly connect the FreeNAS PC to my home PC and have it share the home PC's wireless network so I can take advantage of the gigabit ethernet.
The only caveat is I have no idea how to make this work. Any help?
EDIT:
My home PC is running Windows 7, and NAS is running FreeNAS 8.0.3.
I've turned on Internet Connection Sharing in Windows 7 but it doesn't seem to be working. In Control Panel > Network & Internet > Network Connections, the LAN says 'Unidentified Network'
survive
Behold the Wumpus
Hi NexusB,
I don't there's really a clean way to do this.
My suggestion would be to go out & get a 5 port gig-e switch and put it between the router and your clients, you'll get much better performance using a wired connection than wireless.
-Will
ProtoSD
NexusB,
Will is correct, no matter how good your wifi is, it's unreasonable to expect any decent performance if you plan to stream videos or do backups etc. You'll save yourself a lot of headaches and time if you find yourself a gig-e switch. Even a cheap one to start with is better than wifi.
NexusB
Thank you for your input. I've just ordered a switch and if I have any issues with that, I'll post in here tomorrow. :)
