FreeNAS to Scale Upgrade, fastest/easiest process
linus12
Thanks to all who helped get my New TrueNAS SCALE server up and running. Now on to Step 2: Updating my old FreeNAS server.
Plan is to upgrade my "Personal Server" (See Signature) from FreeNAS -11.3-U5 to TrueNAS Scale (current version).
The current Personal Server has Plex installed along with a number of users and SMB shares, the new version will only have 1 user, no Plex, and some new SMB Shares.
I wish to save 1 Pool (about 4.5TB of data). All other drives will be reconfigured into new pools.
I did think about going the upgrade route, but I figure a clean install would be better.
Upgrade Plan:
  1. Disconnect the 1 Pool for saving
  2. Install TrueNAS Scale
  3. Configure with 1 user (me!)
  4. Define new pools using drives from "destroyed" pools
  5. Reattach the 1 saved Pool
My questions are:
  • Is this a good plan?
    • If not, what would be a better route?
    • If so, How best to go about steps 1 and 5? (point me in the direction of the documentation!)
linus12
Thanks @danb35!
Followup question: Do I need to upgrade the FreeNAS first to TrueNAS Core 13.x first? Or can I export the pool under FreeNAS 11.x and import it under TrueNAS Scale 22.12.x ?
I don't see any reason why not.
