FreeNAS sudden boot problems 8.0.4
habi
After trying another motherboard that was a mistake it seems that my compactflash installation wont boot anymore with all parts that i used before.
Machine says that it "cant find a bootable installation -- insert boot disk and press key".
I am able to boot from my usb installation. And i can fsck the compact flash and everything seems ok with it. I could even a few times load the compact flash installation that i have used for months via boot: "0:ad(1,a)/boot/loader" to load via usb mbr loader to the compact flash. But when i pull the usb key out it will say i dont have a bootable drive. Stupid as i was i didnt copy the configuration via web interface. Now I doesnt seem to boot to anything other thatn usb installation (which i have no configs in).
I also tried to write the mbr with fdisk -B -b ada1 and i only wrote the boot code, but not the partition table. Still i cant boot from the compact flash on its own at all now.
I would like to copy the configuration from the compact flash and try to install again if i dont find other solution by then but does somebody know how to copy configuration directly from the installation that you can mount but not boot from (as i cant use the web interface from the compact flash which has the config)
Im not shure is it a boot0 or boot 1 problem?
cpu_reset: Stopping other CPUs
Copyright (c) 1992-2011 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.2-RELEASE-p7 #0: Thu May 3 12:22:17 PDT 2012
jpaetzel@build.ixsystems.com:/home/jpaetzel/8.0.4-RELEASE-p2/obj.amd64/build/home/jpaetzel/8.0.4-RELEASE-p2/FreeBSD/src/sys/FREENAS.amd64 amd64
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: Intel(R) Atom(TM) CPU 330 @ 1.60GHz (1618.44-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x106c2 Family = 6 Model = 1c Stepping = 2
Features=0xbfe9fbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0x40e31d<SSE3,DTES64,MON,DS_CPL,TM2,SSSE3,CX16,xTPR,PDCM,MOVBE>
AMD Features=0x20100800<SYSCALL,NX,LM>
AMD Features2=0x1<LAHF>
TSC: P-state invariant
real memory = 2147483648 (2048 MB)
avail memory = 2043621376 (1948 MB)
ACPI APIC Table: <INTEL D945GLF2>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s) x 2 HTT threads
cpu0 (BSP): APIC ID: 0
cpu1 (AP/HT): APIC ID: 1
cpu2 (AP): APIC ID: 2
cpu3 (AP/HT): APIC ID: 3
ioapic0: Changing APIC ID to 2
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
acpi0: <INTEL D945GLF2> on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
acpi_button0: <Sleep Button> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
vgapci0: <VGA-compatible display> port 0x30e0-0x30e7 mem 0x90300000-0x9037ffff,0x80000000-0x8fffffff,0x90380000-0x903bffff irq 16 at device 2.0 on pci0
agp0: <Intel 82945G (945G GMCH) SVGA controller> on vgapci0
agp0: detected 7932k stolen memory
agp0: aperture size is 256M
pcib1: <ACPI PCI-PCI bridge> at device 28.0 on pci0
pci1: <ACPI PCI bus> on pcib1
re0: <RealTek 8168/8111 B/C/CP/D/DP/E PCIe Gigabit Ethernet> port 0x2000-0x20ff mem 0x90200000-0x90200fff,0x90000000-0x9000ffff irq 16 at device 0.0 on pci1
re0: Using 1 MSI-X message
re0: Chip rev. 0x3c000000
re0: MAC rev. 0x00400000
miibus0: <MII bus> on re0
rgephy0: <RTL8169S/8110S/8211B media interface> PHY 1 on miibus0
rgephy0: 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Ethernet address: 00:1c:c0:70:a3:e4
re0: [ITHREAD]
pcib2: <ACPI PCI-PCI bridge> at device 28.2 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> at device 28.3 on pci0
pci3: <ACPI PCI bus> on pcib3
uhci0: <Intel 82801G (ICH7) USB controller USB-A> port 0x3080-0x309f irq 23 at device 29.0 on pci0
uhci0: [ITHREAD]
usbus0: <Intel 82801G (ICH7) USB controller USB-A> on uhci0
uhci1: <Intel 82801G (ICH7) USB controller USB-B> port 0x3060-0x307f irq 19 at device 29.1 on pci0
uhci1: [ITHREAD]
usbus1: <Intel 82801G (ICH7) USB controller USB-B> on uhci1
uhci2: <Intel 82801G (ICH7) USB controller USB-C> port 0x3040-0x305f irq 18 at device 29.2 on pci0
uhci2: [ITHREAD]
usbus2: <Intel 82801G (ICH7) USB controller USB-C> on uhci2
uhci3: <Intel 82801G (ICH7) USB controller USB-D> port 0x3020-0x303f irq 16 at device 29.3 on pci0
uhci3: [ITHREAD]
usbus3: <Intel 82801G (ICH7) USB controller USB-D> on uhci3
ehci0: <Intel 82801GB/R (ICH7) USB 2.0 controller> mem 0x903c0000-0x903c03ff irq 23 at device 29.7 on pci0
ehci0: [ITHREAD]
usbus4: EHCI version 1.0
usbus4: <Intel 82801GB/R (ICH7) USB 2.0 controller> on ehci0
pcib4: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci4: <ACPI PCI bus> on pcib4
atapci0: <Promise PDC20375 SATA150 controller> port 0x1080-0x10bf,0x10c0-0x10cf,0x1000-0x107f mem 0x90120000-0x90120fff,0x90100000-0x9011ffff irq 21 at device 0.0 on pci4
atapci0: [ITHREAD]
atapci0: [ITHREAD]
ata2: <ATA channel 0> on atapci0
ata2: [ITHREAD]
ata3: <ATA channel 1> on atapci0
ata3: [ITHREAD]
ata4: <ATA channel 2> on atapci0
ata4: [ITHREAD]
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
atapci1: <Intel ICH7 UDMA100 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0x30b0-0x30bf irq 18 at device 31.1 on pci0
ata0: <ATA channel 0> on atapci1
ata0: [ITHREAD]
atapci2: <Intel ICH7 SATA300 controller> port 0x30c8-0x30cf,0x30ec-0x30ef,0x30c0-0x30c7,0x30e8-0x30eb,0x30a0-0x30af irq 19 at device 31.2 on pci0
atapci2: [ITHREAD]
ata5: <ATA channel 0> on atapci2
ata5: [ITHREAD]
ata6: <ATA channel 1> on atapci2
ata6: [ITHREAD]
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
atrtc0: <AT realtime clock> port 0x70-0x71,0x74-0x77 irq 8 on acpi0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
ppc0: cannot reserve I/O port range
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
coretemp0: Can not get Tj(target) from your CPU, using 100C.
p4tcc0: <CPU Frequency Thermal Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
coretemp1: Can not get Tj(target) from your CPU, using 100C.
p4tcc1: <CPU Frequency Thermal Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
coretemp2: Can not get Tj(target) from your CPU, using 100C.
p4tcc2: <CPU Frequency Thermal Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
coretemp3: Can not get Tj(target) from your CPU, using 100C.
p4tcc3: <CPU Frequency Thermal Control> on cpu3
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Timecounters tick every 1.000 msec
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 12Mbps Full Speed USB v1.0
usbus4: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen2.1: <Intel> at usbus2
uhub2: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen3.1: <Intel> at usbus3
uhub3: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus3
ugen4.1: <Intel> at usbus4
uhub4: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus4
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
uhub2: 2 ports with 2 removable, self powered
uhub3: 2 ports with 2 removable, self powered
uhub4: 8 ports with 8 removable, self powered
ugen4.2: <Kingston> at usbus4
umass0: <Kingston DT 101 G2, class 0/0, rev 2.00/1.00, addr 2> on usbus4
ada0 at ata2 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD20EARS-00MVWB0 51.0AB51> ATA-8da0 at umass-sim0 bus 0 scbus6 target 0 lun 0
da0: <Kingston DT 101 G2 PMAP> Removable Direct Access SCSI-0 device
da0: 40.000MB/s transfers
da0: 3818MB (7819264 512 byte sectors: 255H 63S/T 486C)
SATA 2.x device
ada0: 150.000MB/s transfers (SATA 1.x, UDMA5, PIO 8192bytes)
ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada1 at ata3 bus 0 scbus1 target 0 lun 0
ada1: <CF Card Ver5.04> ATA-5 device
ada1: 150.000MB/s transfers (SATA 1.x, UDMA5, PIO 512bytes)
ada1: 3639MB (7454160 512 byte sectors: 16H 63S/T 7395C)
ada2 at ata5 bus 0 scbus4 target 0 lun 0
ada2: <WDC WD20EARX-00MMMB0 80.00A80> ATA-8 SATA 3.x device
ada2: 150.000MB/s transfers (SATA, UDMA5, PIO 8192bytes)
ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada3 at ata6 bus 0 scbus5 target 0 lun 0
ada3: <WDC WD20EARX-00PASB0 51.0AB51> ATA-8 SATA 3.x device
ada3: 150.000MB/s transfers (SATA, UDMA5, PIO 8192bytes)
ada3: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
SMP: AP CPU #2 Launched!
SMP: AP CPU #1 Launched!
SMP: AP CPU #3 Launched!
GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present;
to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
ZFS filesystem version 4
ZFS storage pool version 15
re0: link state changed to UP
[root@freenas] ~# gpart list -a
Geom name: da0
state: OK
fwheads: 255
fwsectors: 63
last: 7819244
first: 63
entries: 4
scheme: MBR
Providers:
1. Name: da0s1
Mediasize: 988291584 (943M)
Sectorsize: 512
Mode: r1w0e1
attrib: active
rawtype: 165
length: 988291584
offset: 32256
type: freebsd
index: 1
end: 1930319
start: 63
2. Name: da0s2
Sectorsize: 512
Mode: r0w0e0
rawtype: 165
length: 988291584
offset: 988356096
type: freebsd
index: 2
end: 3860639
start: 1930383
3. Name: da0s3
Mediasize: 1548288 (1.5M)
Sectorsize: 512
Mode: r0w0e0
rawtype: 165
length: 1548288
offset: 1976647680
type: freebsd
index: 3
end: 3863663
start: 3860640
4. Name: da0s4
Mediasize: 21159936 (20M)
Sectorsize: 512
Mode: r1w1e2
rawtype: 165
length: 21159936
offset: 1978195968
type: freebsd
index: 4
end: 3904991
start: 3863664
Consumers:
1. Name: da0
Mediasize: 4003463168 (3.7G)
Sectorsize: 512
Mode: r2w1e4
Geom name: da0s1
state: OK
fwheads: 255
fwsectors: 63
last: 1930256
first: 0
entries: 8
scheme: BSD
Providers:
1. Name: da0s1a
Mediasize: 988283392 (943M)
Sectorsize: 512
Mode: r1w0e1
rawtype: 0
length: 988283392
offset: 8192
type: !0
index: 1
end: 1930256
start: 16
Consumers:
1. Name: da0s1
Sectorsize: 512
Mode: r1w0e1
Geom name: ada0
state: OK
fwheads: 16
fwsectors: 63
last: 3907029134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada0p1
Mediasize: 2147483648 (2.0G)
Sectorsize: 512
Mode: r0w0e0
rawuuid: 4f111e67-af2d-11e1-bd21-001cc070a3e4
rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b
label: (null)
length: 2147483648
offset: 65536
type: freebsd-swap
index: 1
end: 4194431
start: 128
2. Name: ada0p2
Mediasize: 1998251367936 (1.8T)
Sectorsize: 512
Mode: r0w0e0
rawuuid: 4f2b9780-af2d-11e1-bd21-001cc070a3e4
rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b
label: (null)
length: 1998251367936
offset: 2147549184
type: freebsd-zfs
index: 2
end: 3907029134
start: 4194432
Consumers:
1. Name: ada0
Mediasize: 2000398934016 (1.8T)
Sectorsize: 512
Mode: r0w0e0
Geom name: ada1
state: OK
fwheads: 16
fwsectors: 63
last: 7454159
first: 63
entries: 4
scheme: MBR
Providers:
1. Name: ada1s1
Sectorsize: 512
Mode: r0w0e0
rawtype: 165
length: 988291584
offset: 32256
type: freebsd
index: 1
end: 1930319
start: 63
2. Name: ada1s2
Sectorsize: 512
Mode: r0w0e0
rawtype: 165
length: 988291584
offset: 988356096
type: freebsd
index: 2
end: 3860639
start: 1930383
3. Name: ada1s3
Sectorsize: 512
Mode: r0w0e0
rawtype: 165
length: 1548288
offset: 1976647680
type: freebsd
index: 3
end: 3863663
start: 3860640
4. Name: ada1s4
Sectorsize: 512
Mode: r0w0e0
rawtype: 165
length: 21159936
offset: 1978195968
type: freebsd
index: 4
end: 3904991
start: 3863664
Consumers:
1. Name: ada1
Mediasize: 3816529920 (3.6G)
Sectorsize: 512
Mode: r0w0e0
Geom name: ada2
state: OK
fwheads: 16
fwsectors: 63
last: 3907029134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada2p1
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
rawuuid: 50a69465-af2d-11e1-bd21-001cc070a3e4
label: (null)
length: 2147483648
offset: 65536
type: freebsd-swap
index: 1
end: 4194431
start: 128
2. Name: ada2p2
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
rawuuid: 50bcc7e9-af2d-11e1-bd21-001cc070a3e4
label: (null)
offset: 2147549184
type: freebsd-zfs
index: 2
end: 3907029134
start: 4194432
Consumers:
1. Name: ada2
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
Geom name: ada3
state: OK
fwheads: 16
fwsectors: 63
last: 3907029134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada3p1
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
rawuuid: 4fde005f-af2d-11e1-bd21-001cc070a3e4
label: (null)
length: 2147483648
offset: 65536
type: freebsd-swap
index: 1
end: 4194431
start: 128
2. Name: ada3p2
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
rawuuid: 4fed9cd6-af2d-11e1-bd21-001cc070a3e4
label: (null)
offset: 2147549184
type: freebsd-zfs
index: 2
end: 3907029134
start: 4194432
Consumers:
1. Name: ada3
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
Geom name: ada1s1
state: OK
fwheads: 16
fwsectors: 63
last: 1930256
first: 0
entries: 8
scheme: BSD
Providers:
1. Name: ada1s1a
Sectorsize: 512
Mode: r0w0e0
rawtype: 0
length: 988283392
offset: 8192
type: !0
index: 1
end: 1930256
start: 16
Consumers:
1. Name: ada1s1
Sectorsize: 512
Mode: r0w0e0
paleoN
You should have a backup of your config. Since you don't, you can stick it into another FreeNAS, or any FreeBSD system, and mount the 4th partition, I believe, and copy freenas-v1.db to a safe place. Then import your old database.
4. Name: da0s4
Should be this one.
