Hi there...
We're using FreeNAS 11.1-U7 as a VM on ESXi 6.7.
I would like help in interpreting the console boot messages.
It seems that at one point, the boot process is busy processing for about 1 minute... but I cannot find anything in /var/logs matching strings to determine what it is doing.
Here's the snippet of console output:
So I'm trying to figure out what it's doing during the 1 minute (in bold) between the "update" plugin_load and "Call timeout"
I can't seem to find any strings that match the plugin-load (e.g. "aggregation", "cputemp", "uptime") in /var/logs.
In /var/logs/messges, I'm able to find matches up to iocage messages, but that was it.
Any help is greatly appreciated.
Thank you.
<normal boot messages - no issues here> * [I|O|C] starting jails... IOCAGE_SKIP is TRUE or an RC operation, no activating a pool. Please manually issue iocage activate POOL Starting consul_alerts. Starting consul. Starting collectd. plugin_load: plugin "aggregation" successfully loaded. plugin_load: plugin "cpu" successfully loaded. plugin_load: plugin "cputemp" successfully loaded. ... <more plugin_load messages> plugin_load: pluging "uptime" sucessfully loaded. < ... It thinks here for 1 minute ... What's it doing? > Call timeout Flushed all rules. <... and the properly finishes to the console setup selection>
Thank you.
