Hi everyone, I have had a search of the forum and couldnt really come up with a confident yes or no answer to my issue.
My current Freenas set up is an intel based running the following config
FreeNAS-11.1-U7
Intel(R) Pentium(R) CPU G4560 @ 3.50GHz
16 GB Ram
3 tb capacity with 3 tb back up drive attached.
I currently use an AMD Ryzen 1700 for my daily driver which I am planning to upgrade to the new Ryzen 9 platform so this will leave me with the 1700 and an x370 motherboard spare.
I would like to swap out the Intel CPU and mobo from my Freenas and replace it with the spare Ryzen 1700 and X370 Mobo.
Wondering if there is a step by step available or if anyone has done a platform swap before and could point out some things I should consider first.
Also should I upgrade the Freenas OS to 11.2 first and then do the swap or do the swap and then upgrade?
FreeNAS-11.1-U7
16 GB Ram
