FreeNAS on virt-manager/qemu can't mount usb3 drive
jerrac
System info:
FreeNAS Version: FreeNAS-11.2-U4.1
16GB of RAM.
I'm running libvirtd and qemu, configuring things via virt-manager. My host OS is Pop_OS 18.04, so basically Ubuntu 18.04.
My issue:
I'm trying to mount an external USB 3 drive so I can backup my data to it.
I'm not sure why, but when I tell virt-manager to use a usb3 controller, I can't mount the drive. If I set it to the default usb2 controller, it mounts.
I was hoping that usb3 would improve my data transfer rate.
For whatever reason, I am unable to add more than 1 USB controller to my vm. I believe that's a limitation of libvirtd, or qemu.
Below is the output I think is useful from the various things I have tried.
(I'm new to the forum, would this have been better posted as a gist or pastebin?)
With USB Controller using usb2:
--------------- Start usb2 output ----------------------
# tail -f /var/log/messages
9 18:04:55 xunlaichest ugen3.2: <Western Digital My Book 1230> at usbus3
Jun  9 18:04:55 xunlaichest umass0 on uhub1
Jun  9 18:04:55 xunlaichest umass0: <Western Digital My Book 1230, class 0/0, rev 3.00/10.65, addr 2> on usbus3
Jun  9 18:04:55 xunlaichest umass0:  SCSI over Bulk-Only; quirks = 0x8000
Jun  9 18:04:55 xunlaichest umass0:14:0: Attached to scbus14
Jun  9 18:04:55 xunlaichest da0 at umass-sim0 bus 0 scbus14 target 0 lun 0
Jun  9 18:04:55 xunlaichest da0: <WD My Book 1230 1065> Fixed Direct Access SPC-4 SCSI device
Jun  9 18:04:55 xunlaichest da0: Serial Number 574343344532585435535835
Jun  9 18:04:55 xunlaichest da0: 40.000MB/s transfers
Jun  9 18:04:55 xunlaichest da0: 3815415MB (976746240 4096 byte sectors)
Jun  9 18:04:55 xunlaichest da0: quirks=0x2<NO_6_BYTE>
Jun  9 18:04:55 xunlaichest ses0 at umass-sim0 bus 0 scbus14 target 0 lun 1
Jun  9 18:04:55 xunlaichest ses0: <WD SES Device 1065> Fixed Enclosure Services SPC-4 SCSI device
Jun  9 18:04:55 xunlaichest ses0: Serial Number 574343344532585435535835
Jun  9 18:04:55 xunlaichest ses0: 40.000MB/s transfers
Jun  9 18:04:55 xunlaichest ses0: SCSI-3 ENC Device
root@xunlaichest[~]# gpart show
=>        34  7814037101  ada0  GPT  (3.6T)
          34      262144     1  ms-reserved  (128M)
      262178        2014        - free -  (1.0M)
      264192  7813771264     2  ms-basic-data  (3.6T)
  7814035456        1679        - free -  (840K)
=>      40  67108784  ada1  GPT  (32G)
        40    532480     1  efi  (260M)
    532520  66551808     2  freebsd-zfs  (32G)
  67084328     24496        - free -  (12M)
=>        40  7814037088  ada2  GPT  (3.6T)
          40          88        - free -  (44K)
         128     4194304     1  freebsd-swap  (2.0G)
     4194432  7809842696     2  freebsd-zfs  (3.6T)
=>        40  7814037088  ada3  GPT  (3.6T)
=>        40  7814037088  ada4  GPT  (3.6T)
=>        34  7814037101  ada5  GPT  (3.6T)
=>       63  976746177  da0  MBR  (3.6T)
         63        193       - free -  (772K)
        256  976745984    1  ntfs  (3.6T)
root@xunlaichest[~]# ls /dev/da*
/dev/da0    /dev/da0s1
root@xunlaichest[~]# mkdir /mnt/mybook
root@xunlaichest[~]# mount_ntfs /dev/da0s1 /mnt/mybook
fuse: failed to open fuse device: No such file or directory
root@xunlaichest[~]# kldload fuse
root@xunlaichest[~]# ls /mnt/mybook
<list of dirs>
--------------- End usb2 output ----------------------
With USB Controller set to usb3:
--------------- Start usb3 output ----------------------
root@xunlaichest[~]# tail -f /var/log/messages
Jun  9 18:11:10 xunlaichest ugen0.2: <Western Digital My Book 1230> at usbus0
Jun  9 18:11:10 xunlaichest umass0 on uhub0
Jun  9 18:11:10 xunlaichest umass0: <Western Digital My Book 1230, class 0/0, rev 3.00/10.65, addr 1> on usbus0
Jun  9 18:11:10 xunlaichest umass0:  SCSI over Bulk-Only; quirks = 0x8000
Jun  9 18:11:15 xunlaichest umass0: Get Max Lun not supported (USB_ERR_TIMEOUT)
Jun  9 18:11:15 xunlaichest umass0:14:0: Attached to scbus14
Jun  9 18:11:15 xunlaichest da0 at umass-sim0 bus 0 scbus14 target 0 lun 0
Jun  9 18:11:15 xunlaichest da0: <WD My Book 1230 1065> Fixed Direct Access SPC-4 SCSI device
Jun  9 18:11:15 xunlaichest da0: Serial Number 574343344532585435535835
Jun  9 18:11:15 xunlaichest da0: 400.000MB/s transfers
Jun  9 18:11:15 xunlaichest da0: 3815415MB (976746240 4096 byte sectors)
Jun  9 18:11:15 xunlaichest da0: quirks=0x2<NO_6_BYTE>
Jun  9 18:11:15 xunlaichest ses0 at umass-sim0 bus 0 scbus14 target 0 lun 1
Jun  9 18:11:15 xunlaichest ses0: <WD SES Device 1065> Fixed Enclosure Services SPC-4 SCSI device
Jun  9 18:11:15 xunlaichest ses0: Serial Number 574343344532585435535835
Jun  9 18:11:15 xunlaichest ses0: 400.000MB/s transfers
Jun  9 18:11:15 xunlaichest ses0: SCSI-3 ENC Device
^C
/dev/da0    /dev/da0s1
Failed to read bootsector (size=0)
Failed to mount '/dev/da0s1': Invalid argument
The device '/dev/da0s1' doesn't seem to have a valid NTFS.
Maybe the wrong device is used? Or the whole disk instead of a
partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?
--------------- End usb3 output ----------------------
I spent several hours searching this forum, and Google, to find help. What I've tried effectively boils down to the output I've shared here.
Any suggestions would be appreciated. I think I've shared the system info you would need, let me know if I missed something.
Thanks in advance. :)
Chris Moore
USB3 is not well supported in my experience. It is most likely something you need to connect by way of a SATA or SAS controller.
Chris Moore
"Absolutely must virtualize FreeNAS!" ... a guide to not completely losing your data.
https://www.ixsystems.com/community...ide-to-not-completely-losing-your-data.12714/
Virtually FreeNAS ... an alternative for those seeking virtualization
https://www.ixsystems.com/community...ative-for-those-seeking-virtualization.26095/
FreeNAS 9.10 on VMware ESXi 6.0 Guide
https://b3n.org/freenas-9-3-on-vmware-esxi-6-0-guide/
Chris Moore
When you have a long formatted text listing, it is best to use code tags to preserve the formatting.
Like this [CODE]your text here[/CODE] which looks like this in your post:
your text here
jerrac
Is the lack of usb3 support a FreeBSD thing? Should I just give up on getting it working?
It's an external HDD, so I can't just switch to SATA.
I did read the "Absolutely must virtualize FreeNAS!" ... a guide to not completely losing your data. post. :) I tried to read "Please do not run FreeNAS in production as a Virtual Machine!", but it asks for a login...
Thanks for the tip about the code bbcode. I didn't see the option on the toolbar, so I didn't think to just try it... :\
