larsaskogstad
- Mar 1, 2020
Hello.
Just installed FreeNAS-11.3-U1 and thought I managed to get it right the first time (of course not)..
I managed to tick off 2x Crucial 256gb SSD drives to install FreeNAS on, didnt think much of it, thought I could change it later on.
But somehow managed to just install it on both drives and then the problems started.
So I tried reinstalling it, chose 1 of the SSD (ada0) and everything seemed fine but ada1 is still "linked" with the ada0 (which is the only disk I want to be a freenas-boot).
I want to use the spare ssd for plugins later on.
Problem is I don't see any wipe settings in storage, Ive tried gpart and DD the sectors off but it doesnt seem to work.
Is there a way to just "start over" with the install so it wipes over existing data?
root@freenas[~]# gpart show
=> 40 488397088 ada0 GPT (233G)
40 1024 1 freebsd-boot (512K)
1064 33554432 3 freebsd-swap (16G)
33555496 454819840 2 freebsd-zfs (217G)
488375336 21792 - free - (11M)
=> 40 488397088 ada1 GPT (233G)
40 1024 - free - (512K)
=> 40 7814037088 da5 GPT (3.6T)
40 88 - free - (44K)
128 4194304 1 freebsd-swap (2.0G)
4194432 7809842696 2 freebsd-zfs (3.6T)
=> 40 7814037088 da4 GPT (3.6T)
=> 40 7814037088 da3 GPT (3.6T)
=> 40 7814037088 da1 GPT (3.6T)
=> 40 7814037088 da7 GPT (3.6T)
=> 40 7814037088 da6 GPT (3.6T)
=> 40 7814037088 da0 GPT (3.6T)
=> 40 7814037088 da2 GPT (3.6T)
Everything is working fine, the disks shows up under disk, the HBA is working fine as well.
Not sure what to do..
I forgot when settin up the server that FreeNAS requires a drive, I would go for USB sticks but I've tried that before and it always ends up bad for me even with good sticks.
All help is appreciated, thank you. :)
My setup:
Supermicro X10SRL-F
Xeon E5-1650v3
LSI 5Gbps SAS HBA LSI 9211-8i (=9201i-8i) P20 flashes to IT mode
8 X HGST 7200rpm
2 X Cruical MX500 256GB SSD
1300W PSU
My setup:
Supermicro X10SRL-F
Xeon E5-1650v3
8 X HGST 7200rpm
1300W PSU
