Hi All,
First of all, I'd like to introduce myself since I'm new in this forum.
My name is Patricio, I'm from Argentina and I work as an IT consultant on Binnaris IT consulting.
I've been using FreeNAS since version 0.7.2 Sabanda (revision 6694), in fact that's server I've installed on 2011 and never had a single issue. Clearly FreeNAS is one of the best NAS systems ever.
A few days ago, a client asked if there is possible to install FreeNAS on a IBM System x3850 standard
(as far as I know, this is a base server and the disks are yet to be bough and installed)
Here are the specs of this machine:
http://www-03.ibm.com/systems/x/hardware/enterprise/x3850x5/specs.html
http://www-304.ibm.com/shop/america...1686018425279711&dualCurrId=73&catalogId=-840
I've googled if there was any info about this specific kind of installation, but I've found nothing.
My primary concern about this is:
Will the disk controllers allow to connect the disks WITHOUT using the RAID function?
Since the best characteristic of FreeNAS is to be able to use ZFS (on RAIDZ, RAIDZ2 or RAIDZ3), what sense would it make to be forced to use the disks on a hardware RAID configuration?
If Im not wrong, the best of using a ZFS RAID is to be able to replace a broken disk with no
trouble other than change it for a new one and perform a zpool resilver.
Given the case of this server's disk controller will not permit a "JBOD" configuration, it's a good call to install and configure FreeNAS to use the RAIDX, provided by the controller?
Thank you in advance for all the info and advice you could provide about this!
FIRST 3 PEOPLE WHO ANSWERS WINS A FREE & UNLIMITED BEER IN ARGENTINA! ;-)
