I have a problem with the FreeNAS Mini I recently purchased from iXsystems.
My problem: I am not able to establish a TCP/IP connection; even over the IPMI management port. The FreeNAS Mini is a headless server, so my previous recovery strategies do not really apply.
My question: Having lost IP connectivity, what recovery strategies are there for a headless server like my FreeNAS Mini?
Background information: Initially I was able to use the HTML GUI via Firefox without issue. What started this problem was a change made to an unused ethernet interface (igb1); I was using igb0 at the time. After saving an IP address change, an error was displayed, and from there...well, things just got worse. So this does not look like a hardware problem. More likely a user problem. iXsystems do not offer support unless the issue is hardware related; an automated response from iXsystems directed me to this forum. So far I have not found anything in the FreeNAS documentation or on the internet. Which does not mean there isn't anything to find, I just have not found anything yet. If anyone has any tips, please share :)
Strategies going forward: Without the use of any of the ethernet ports, I can still establish alternative access by attaching a keyboard to a USB port or attaching a PC to the serial port. But having done so, I will still be staring out into a bottomless pit as to what should come next: There is no standard output to a screen nor any speaker to sound a beep. I am hoping the serial port, by default, is used as a standard output. If so, by tomorrow I will have a null modem cable to monitor the serial port during the boot process. I may end up searching for how to change the boot device priority should a clean install be required. Sigh.
If anyone can help, I thank you in advance and appreciate your time.
