I have installed FreeNAS 11-3-U1 on a ESXi VM.
ESXi VM - ESXi vswitch on VLAN ID 4095 - Brocade switch with tagged ports on VLAN 40 (pfsense is on it too with a tagged port) - pfsense with VLAN 40 configured and firewall rules allowing traffic.
FreeNAS VM Shell:
ESXi FreeNAS configuration:
Brocade switch configuration (I have tested that vmnic4 and vmnic5 are on 1/1/13 and 1/1/14 switch ports disconnecting cables and refreshing ESXi UI):
pfsense configuration:
pfsense vlan40 rules configuration:
Please, let me know if I missed any data that will be helpful for my problem resolution.
if I delete vlan40 interface in FreeNAS and set vmx0 to 10.0.40.2 address and default gateway to 10.0.40.1 and then set my ESXi vswitch configuration to VLAN ID 40, then I have networking and I can see on pfsense that it is tagged with vlan 40 ID. You can see it in the next image:
so, if I am correct, the problem is on the FreeNAS VM configuration or on ESXi vswitch when configuring it as VLAN ID 4095, but this VLAN ID should set VGT mode and the vswitch port in trunk mode.
all help will be appreciated. Thank you in advance.
FreeNAS VM Shell:
