proto
 - Sep 28, 2015
Hi all,
I have an issue binding an interface to SSH. Whenever I try to assign a LAGG IF to SSH service via web console I get this error:
“Value u'lagg41' is not a valid choice.”
Build is:
FreeNAS-9.10-STABLE-201606072003 (696eba7)
On Supermicro, six intel NICs (see signature for other details)
On FreeNAS server LAGG41 (Admin100) was created via shell menu and it’s assigned to VLAN100, so no tag is needed as far as I remember.
VLAN10 is assigned to Admin10 on FreeNAS and I assigned SSH and HTTPS management services. This is a tagged vlan.
I can successfully bind other services to LAGG41, ie: http(s), nfs.
Then I executed these queries I found in /usr/local/www/freenasUI/choices.py:
# Networking is ok, I hope:
Finally this is my HP v1910 configuration:
BAGG1 (LAGG0 on FreeNAS used for storage services)
BAGG2 (LAGG41 on FreeNAS / tagged vlan10 (Admin10) and untagged vlan100 Admin100)
Why I can't get my lagg41 working?
Thanks!
Build is:
# sqlite3 /root/dbcopy.db sqlite> select id,ssh_bindiface from services_ssh; id|ssh_bindiface 1|vlan10 sqlite> select int_ipv4address,int_name,int_interface from network_interfaces; int_ipv4address|int_name|int_interface 10.10.40.1|NFS40|lagg0 10.10.50.1|Storage50|vlan50 10.10.100.110|Admin100|lagg41 10.10.10.110|Admin10|vlan10 sqlite> select * from network_lagginterface; id|lagg_interface_id|lagg_protocol 1|2|loadbalance 2|5|loadbalance sqlite> select * from network_lagginterfacemembers; id|lagg_interfacegroup_id|lagg_ordernum|lagg_physnic|lagg_deviceoptions 1|1|0|igb2|up 2|1|1|igb3|up 3|1|2|igb4|up 4|1|3|igb5|up 5|2|0|igb0|up 6|2|1|igb1|up sqlite> select * from network_vlan; vlan_pint|vlan_description|vlan_vint|id|vlan_tag lagg0|NFS40|vlan40|1|40 lagg0|Storage50|vlan50|2|50 lagg41|Admin10|vlan10|3|10
sqlite> SELECT lagg_physnic FROM network_lagginterfacemembers; igb0 igb1 igb2 igb3 igb4 igb5 sqlite> SELECT vlan_pint FROM network_vlan; lagg0 lagg0 lagg41 sqlite> SELECT vlan_pint FROM network_vlan INNER JOIN network_interfaces ON network_vlan.vlan_pint=network_interfaces.int_interface WHERE network_interfaces.int_interface IS NOT NULL AND ((network_interfaces.int_ipv4address != '' AND network_interfaces.int_ipv4address IS NOT NULL) OR network_interfaces.int_dhcp = 1); lagg0 lagg0 lagg41
# ifconfig lagg41
lagg41: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO>
    ether 0c:c4:7a:32:ce:a6
    inet 10.10.100.110 netmask 0xffffff00 broadcast 10.10.100.255
    media: Ethernet autoselect
    status: active
    laggproto loadbalance lagghash l2,l3,l4
    laggport: igb0 flags=4<ACTIVE>
    laggport: igb1 flags=4<ACTIVE>
port link-type trunk interface Bridge-Aggregation1 undo port trunk permit vlan 1 port trunk permit vlan 40 50 port trunk pvid vlan 40
interface Bridge-Aggregation2 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 10 100 port trunk pvid vlan 100
Thanks!
