FreeNAS + IPMI
I recently upgraded my FreeNAS server with a Supermicro X9 board that has a dedicated IPMI, is FreeNAS capable of getting stats and sensor info from IPMI?
I saw on the FreeNAS network page it now lists IPMI and allows me to select the channel (1) and enter a password and DHCP/static IP in to I assume set up IPMI.
I can of course hit the IPMI from its static IP address and see the sensor data and all, but is FreeNAS able to gather info from it, and if so, what?
Specifically this board https://www.supermicro.com/products/motherboard/xeon/c600/x9dr3-ln4f_.cfm
Mirfster
oh ok thats coo, I figured it was the IPMI tool, I plan to do any monitoring via SNMP once I figure out if I can get my board and PSU to play nicely with power usage and all.
I'm using a Supermicro SC846E16-R1200B superchassis. I had to move a few stand off's and I ended up having 1 that wouldnt line up at all.
As far as power, I'm not sure...but I know it has to be less then my old X8 build
