FreeNAS & insync - google drive sync
is there any implementation for freenas yet?
i need to use insync via freenas.
thanks for any adice on this!
joeschmuck
Old Man
The problem isn't FreeNAS, it's Insync, they do not support FreeBSD. My advice is to wait for FreeNAS 10 and then try Bhyve to create a Linux VM to support insync. You could use IOHyve on the current FreeNAS as well. I just don't know how well Linux is supported but it should be.
