FreeNAS installation problems (screen)
szupes
Hi. I have a problem with installation of FreeNAS. My hardware spec:
Case: CoolerMaster Elite 110A
Motherboard: AsRock J4205-ITX (with 1.8 bios version - latest)
RAM: 2 x 8 GB Kingston DDR3L
Drives: 1 x SSD 60GB (for system)
1 x SSD 512 GB (for DATA)
PSU: picoPSU 160w + Seasonic Power Supply 80W
As you can see on a screen attatched my bootable flashdrive (16GB) booting OK but later on I have got those messages. Other OS was installed without any problems (openmediavault, Ubuntu, Win10) but only FreeNAS have a problems with. Please help me solve the issue. Thank you
artlessknave
this looks like hardware that would not be on the recommendations lists.
taking a stab at it, it looks like either your storage controller is, unsurprisingly, flaking out, or your SSD is flaking out.
cam status is to my knowledge not really applicable to SSD, so I would tend toward the controller not behaving correctly and the storage subsystem on bsd seeing it as timeouts and basically panicking.
it looks like there are 2 different controllers, switching your drive to the ports on the other controller might give you different results.
zfs, and bsd, tend to be more likely to find weak points in storage hardware, and is one of the reasons for recommended hardware.
TL:DR non recommended hardware is not recommended for a reason.
