Freenas for 2-way sync
hans2k6
I learned freenas to know at my new job.
Since then I like it very well.
At home I am now using WinSrv DFS to sync my computers in different locations.
Is it possible to use zfs replication in a two way sync?
Or is it not recommended?
thanks
jgreco
Resident Grinch
No. ZFS replication is not for two way synchronization. You need something like Unison if you wish to try that.
John M. Długosz
I have a similar question on my list. If I keep my work on a local drive and then copy the directory to the ZFS server each day, I want to avoid sending the entire thing all over again (or reading the old over the network to determine it is the same). So I want something that cooperates with the server to determine what needs to be sent.
I thought I noticed rsync mentioned in the manual. Is that indeed running on FreeNAS and useful for sync'ing a Windows machine using NTFS?
I use Unison for my web server. It's a pain because the versions must match exactly and that's difficult across platforms. But, is Unison running on FreeNAS, available as a module, or what?
N00b
hans2k6
hm. I am already using BTSync on my macs.
Maybe I should try it to get running on freenas :-/
anika200
The download and instructions for startup in a jail are below.
The download is Here.
The Instructions and startup script are Here.
I have been using it for about a week and it seems pretty good but it has limitations too. I would not rely on it for anything too critical just yet. According to the information I read it is best for large files and not so good for a bunch of smaller files. On the other hand, rsync is built in to FreeNAS and has a proven track record.
ThomasDK81
Won't Owncloud be a viable solution/alternative?
I saw a plugin or was it a guide, here some where.
We want data stored on our NAS right?
Whattteva
Owncloud is more for easy access to your data from other devices, not really for data replication like what OP is trying to do.... (I think?!)
EDIT: Nevermind, I replied to this thread, but my mind was on another thread that was about replication for backups.
hans2k6
Yes, I only want to replicate to file servers on those me and my family working and the same time.
