FreeNAS Errors on Console
DarkSorrow
Been running FreeNAS for about a week now. Everything seems to run good. I noticed on the console the following error messages however. I'm confused. Shouldn't I be getting emails on these errors? I have it setup to use my mail server to send on issues.
No, those errors aren't emailed. They'd appear at the bottom of the web GUI if you have that option enabled (which I'd recommend). They're also the result of a bug in collectd, which hopefully will be fixed with 11.1.
DarkSorrow
Off hand where is the option to enable it on the GUI? So nothing to worry about with these errors then. Thanks.
Sent from my Samsung Galaxy S8 Plus
BigDave
FreeNAS Enthusiast
DarkSorrow
Ok, I did that. It's really tiny lol. Looks good when I click it however :)
Sep 14 11:59:49 freenas ZFS: vdev state changed, pool_guid=7299094349182909605 vdev_guid=13468870268020745477
Sep 14 12:00:08 freenas notifier: Installing for i386-pc platform.
Sep 14 12:00:16 freenas notifier: Installation finished. No error reported.
Sep 14 12:10:07 freenas collectd[4337]: aggregation plugin: Unable to read the current rate of "freenas.local/cpu-4/cpu-user".
Sep 14 12:10:07 freenas collectd[4337]: utils_vl_lookup: The user object callback failed with status 2.
Sep 14 12:33:47 freenas collectd[4337]: aggregation plugin: Unable to read the current rate of "freenas.local/cpu-10/cpu-nice".
Sep 14 12:33:47 freenas collectd[4337]: utils_vl_lookup: The user object callback failed with status 2.
Sep 14 12:59:17 freenas collectd[4337]: aggregation plugin: Unable to read the current rate of "freenas.local/cpu-20/cpu-interrupt".
Sep 14 12:59:17 freenas collectd[4337]: utils_vl_lookup: The user object callback failed with status 2.
Sep 14 13:02:17 freenas collectd[4337]: aggregation plugin: Unable to read the current rate of "freenas.local/cpu-6/cpu-user".
Sep 14 13:02:17 freenas collectd[4337]: utils_vl_lookup: The user object callback failed with status 2.
Sep 14 13:03:27 freenas collectd[4337]: aggregation plugin: Unable to read the current rate of "freenas.local/cpu-9/cpu-user".
Sep 14 13:03:27 freenas collectd[4337]: utils_vl_lookup: The user object callback failed with status 2.
Sep 14 14:07:17 freenas collectd[4337]: aggregation plugin: Unable to read the current rate of "freenas.local/cpu-3/cpu-user".
Sep 14 14:07:17 freenas collectd[4337]: utils_vl_lookup: The user object callback failed with status 2.
Sep 14 14:36:17 freenas collectd[4337]: aggregation plugin: Unable to read the current rate of "freenas.local/cpu-6/cpu-user".
Sep 14 14:36:17 freenas collectd[4337]: utils_vl_lookup: The user object callback failed with status 2.
Sep 14 15:10:57 freenas collectd[4337]: aggregation plugin: Unable to read the current rate of "freenas.local/cpu-10/cpu-user".
Sep 14 15:10:57 freenas collectd[4337]: utils_vl_lookup: The user object callback failed with status 2.
Sep 14 15:20:57 freenas collectd[4337]: aggregation plugin: Unable to read the current rate of "freenas.local/cpu-8/cpu-idle".
Sep 14 15:20:57 freenas collectd[4337]: utils_vl_lookup: The user object callback failed with status 2.
Jailer
Not strong, but bad
