FreeNAS Download Not Initiating
_Will_
_Will_
Downloading from your first link still didn't work.
Downloading from the second link does work. Thank you very much.
Edit: For anyone else having this issue. If you go to the main download page and click on "FreeNAS 9.2.1.5" rather than the download button itself, that works too. It defaults to downloading the 64-bit version.
I just tried it and it worked for me.... both links. /shrug
solarisguy
@_Will_, do you have JavaScript enabled, pop-ups enabled etc. ? Or can you make that web address a trusted one so everything works and retry?
_Will_
I'm at a friends house now, and I just tried the regular download button and it works. On Monday I'll try it again and see if it works from my work computer. If it doesn't I'll check to see if I have JavaScript and pop-ups enabled. I'll get back to you. Thanks for the input!
john999boy
I've got the exact same problem as well!
I'm trying to download the 64bit upgrade file and zilch - same with the 32bit. However all the other files will download okay.
Can someone else try either of the two files to confirm if it's a global problem please?
