FreeNAS - Compatible SATA Cards??
S
Seth Walker
Guest
Hi Everyone,
I currently have a SuperMicro Intel ATOM Motherboard (http://www.supermicro.com/products/m...m?typ=H&IPMI=Y) that has 6 SATA slots on it. I have all SATA slots full of 2 TB Harddrives.
There is a PCI-e 16x slot on there.
Is there a way to add more SATA harddrives to this motherboard that FreeNAS will support?
S
Seth Walker
Guest
And these will automatically work with FreeNAS? Most likely will get the 4 port.
kleinejan
I have the same board Supermicro with Atom 510 and 6 ports. Also needed more Sata ports for my data hungry NAS. I bought a Lycom PCIe card (PE-100N) with a SiI3132 chipset. This works in Freenas 7 & 8. The card is cheap but gives you only one extra internal port. Then I discovered "Port multipliers" also from Lycom (ST-126) with a SiI3726 chipset. Does not work in Freenas 7 but works great in Feenas 8! Because the kernel has support for these chipsets. FN7 doesn't. For under €80,- you have 6 extra ports. That's cheaper then any raid/sata card I could find.
Don't know how much speed loss you get, because of the bandwidth on one PCIe card. Can only say it works good enough for me :)
Before you buy a card check the chipset. I was not planning in using freenas 8, but I had to because of the SiI3726 support. Waiting for the big 8.1 update :)
S
Seth Walker
Guest
Awesome thanks!
survive
Behold the Wumpus
Hi guys,
If you are willing to slum through ebay you can find lots of LSI 1068 based cards for sale for cheap. Look for:
Dell SAS/5 <--- 4 port PCI-e 8X
IBM BR10i <--- 8 port PCI-e 8X
You will probably spend more for cables than you will for the cards!
This guy has a pretty good list of SAS controllers posted:
http://blog.zorinaq.com/?e=10
-Will
Tekkie
Thanks for that posting Will! :)
khelm
yup, here are 2 options i use and know work great.
4port
http://www.newegg.com/Product/Product.aspx?Item=N82E16816124027
8port
http://www.newegg.com/Product/Product.aspx?Item=N82E16816118100
the second one is a bid card and needs extra cables that don't come with it, miniSAS fanout or something like that
http://www.newegg.com/Product/Product.aspx?Item=N82E16816151080&cm_re=miniSAS-_-16-151-080-_-Product
i did have to add extra cooling to the second one.
I have a couple of questions on the AOC-USAS-L8i that is recommended.
1. Does it support drive spindown?
2. Does it support 3TB Drives?
3. Does it need flashed with the IT firmware?
Thanks,
Kerry
survive
Behold the Wumpus
Hi khelm,
I took a look at the product page for the AOC-USAS-L8i and it looks like the card is based off the LSI 1068 chip.
I have a similar card (IBM BR10i) and I can get the drives to spindown using a script I found here:
http://forums.freenas.org/showthrea...ATA-drive-spindown&p=5605&viewfull=1#post5605
The 1068 chip will not support 3TB drives. According to the product page the Supermicro card ships with the "IT" firmware.
-Will
