baummer
- Feb 15, 2014
After weeks of research, and some playing around in a FreenNAS 9.10 VM, here is my proposed build for an ESXi all-in-one FreeNAS server that will function as a file backup server and Plex media server (one user only), as well as host a few VMs for web development purposes:
- CPU: Intel Xeon E3-1230v5 3.40GHz
- Motherboard: Supermicro MBD-X11SSM-F-O
- RAM: 2x16GB Crucial ECC RAM
- Storage:
- 2x16GB Sandisk Cruzer Fit USB (FreeNAS boot drive mirroed)
2x160GB Intel DC3500 SSD (as a datastore for FreeNAS mirrored installation)- 6x3TB WD Red (RAIDZ2 configuration for use in FreeNAS pool)
- HBA: IBM Serveraid M1015 (flashed to IT mode)
- PSU: ??? - gold rated, unsure
- Case: Fractal Node 804
- I do need an HBA, right? Assuming yes:
The Sandisk Cruzer Fit USB boot drive - I assume this should be connected directly to the motherboard and not the HBA?- Should the rest of the storage (6x3TB WD Red
and 2x160GB Intel DC3500 SSD) connect to the HBA or should some of it connect straight to the motherboard?
By my wattage calculation, I believe I can get by with a 300W or higher PSU. Do you agree? If so, any PSU brands to avoid?Do I need a SLOG? If so, would adding another 160GB Intel DC3500 SSD work for that purpose? I've read conflicting information on this and would appreciate guidance here.- Anything else I am missing?
