I'm considering setting up a Freenas server for use as a network file share but with the intention to also use it to run Plex from the server to serve media files.
It would at most be two video streams simultaneously and probably only very rarely. It might be used to stream music and a video stream simultaneously but probably nothing more than that Plex wise. I don't tend to watch anything in 4k and sometimes don't even go as high as 1080 so I could well be over spec'ing for current use but don't mind building in a little future proofing now.
Most of the files stored on the Nas will be media files (videos, audio) as well as using it as a file sharing area to allow files to be accessed across PCs for files such as images from my DSLR and basic documents.
All of the access will just be in home as I'm not too bothered about making the files available when away from home.
I've been speccing up a system and currently looking at going with:
Intel Core i5-10400 2.9 GHz 6-Core Processor
Noctua NH-L9i 33.84 CFM CPU Cooler
Gigabyte B560M DS3H Micro ATX LGA1200 Motherboard
Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory
4x Western Digital WD Red Plus 6TB 3.5"
Fractal Design Node 804 MicroATX Mid Tower
Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply
I'm wondering whether the best setup for this would be to use RaidZ2 or simply just basic mirroring and having 2 sets of drives.
I'm intending on having backups in placed outside of the Nas server for the files that are most important (camera files and documents) so I'm mainly wanting to ensure the best setup for running the Nas at suitable speeds for using to stream media via Plex.
Any thoughts on the above welcome. Thanks
