I don't know if there's really any hope for me but I figured I would try and ask in the forums since there are much more knowledgeable people out there than me when it comes to FreeNAS.
Hardware:
- Dell Poweredge T140
- 3 X 1TB sata drives
Software:
- FreeNAS 11.3 (not sure the exact version, since I can't boot)
Mainly use FreeNAS for SMB filesharing.
Everything was working fine, except for new drives that I tried to map were not mapping (kept getting failed credentials even though I was using the correct ones).
Tried connecting to the GUI, but got something like this related post where it would hang at connecting to NAS.
Went to the physical machine and viewed the screen where it said something about ethernet reestablished(don't think it was related).
Normal options were presented. I selected the option to reboot, and nothing happened for an hour. So I did a hard reboot using the power button on the machine.
When the machine came back online it now gives me:
I started to panic when it said "panic: No bootable partitions found"
I'm familiar, but also still a newb when it comes to this stuff. So I didn't even think to make a backup of configurations. Nor did I know that you could clone the operating system onto other USB drives...
Is there any way to recover from this?
I also had jails set up, is that stored on the hard drives, or am I in trouble there too?
Hardware:
Software:
Load Path: \EFI\BOOT\BOOTX64.EFI Load Device: PciRoot (0x0) /Pci (0x14,0x0) /USB (0x10,0x0) /HD (1,GPT,5D2C7CF8-645C-11EA-BA5B-...,0x28,0x82000) BootCurrent: 0000 BootOrder: 0009 0001 0000[*] Probing 12 block devices........+.+.+ done ZFS found the following pools: FilePool UFS found no partitions Failed to load '/boot/loader/.efi' panic: No bootable partitions found! Boot Failed: Disk connected to front USB1: No boot device available or Operating System detected. Please ensure a compatible bootable media is available.
