SOLVED FreeNAS-9.3-STABLE-201509022158 - How to install owncloud
Ladowali
Hi Group,
I have installed own cloud plugin 8.1.1 but it can not be turned ON. can some one help me.
Thanks
Joshua Parker Ruehlig
from the owncloud jail can you ping your computer?
what happens when you run the following?
service apache24 onestart
Ladowali
Hi Joshua,
Please see below:
root@owncloud_1:/ # service apache24 onestart Performing sanity check on apache24 configuration: AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1. Set the 'ServerName' directive globally to suppress this message Syntax OK Starting apache24. AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1. Set the 'ServerName' directive globally to suppress this message root@owncloud_1:/ #
Regards
Ladowali
Hi Joshua,
Please see below:
Regards
Regarding Ping:
root@owncloud_1:/ # ping 192.168.2.58 PING 192.168.2.58 (192.168.2.58): 56 data bytes 64 bytes from 192.168.2.58: icmp_seq=0 ttl=64 time=0.045 ms 64 bytes from 192.168.2.58: icmp_seq=1 ttl=64 time=0.020 ms 64 bytes from 192.168.2.58: icmp_seq=2 ttl=64 time=0.020 ms 64 bytes from 192.168.2.58: icmp_seq=3 ttl=64 time=0.029 ms 64 bytes from 192.168.2.58: icmp_seq=4 ttl=64 time=0.021 ms 64 bytes from 192.168.2.58: icmp_seq=5 ttl=64 time=0.028 ms 64 bytes from 192.168.2.58: icmp_seq=6 ttl=64 time=0.028 ms 64 bytes from 192.168.2.58: icmp_seq=7 ttl=64 time=0.023 ms 64 bytes from 192.168.2.58: icmp_seq=8 ttl=64 time=0.023 ms 64 bytes from 192.168.2.58: icmp_seq=9 ttl=64 time=0.027 ms 64 bytes from 192.168.2.58: icmp_seq=10 ttl=64 time=0.022 ms 64 bytes from 192.168.2.58: icmp_seq=11 ttl=64 time=0.023 ms 64 bytes from 192.168.2.58: icmp_seq=12 ttl=64 time=0.027 ms 64 bytes from 192.168.2.58: icmp_seq=13 ttl=64 time=0.022 ms 64 bytes from 192.168.2.58: icmp_seq=14 ttl=64 time=0.022 ms 64 bytes from 192.168.2.58: icmp_seq=15 ttl=64 time=0.028 ms 64 bytes from 192.168.2.58: icmp_seq=16 ttl=64 time=0.023 ms 64 bytes from 192.168.2.58: icmp_seq=17 ttl=64 time=0.029 ms 64 bytes from 192.168.2.58: icmp_seq=18 ttl=64 time=0.030 ms 64 bytes from 192.168.2.58: icmp_seq=19 ttl=64 time=0.022 ms 64 bytes from 192.168.2.58: icmp_seq=20 ttl=64 time=0.029 ms
does owncloud show as 'On' on the Plugins > Installed tab now?
Ladowali
Hi Joshua,
Please see attached.
Regards
the plugin middleware isn't being communicated to. can you try restarting the owncloud jail
Ladowali
Hi Joshua,
Ok great, its working now. What is the user name and password and how can I attach the designated folder to the own cloud to access it from the outside. Is there any documentation that can show how to access the owncloud from outside my network/
Please see attached:
Thanks and Regards
Hi Joshua,
Thanks and Regards
please read the box you are inputing to carefully, it says it right there.
as for "attaching" a folder, you mean using an owncloud desktop client? did you even try installing the client from owncloud.org?
just like you would allow access to anything outside your network. port forward (in this case 80 or 443 TCP) to your jail IP.
Ladowali
Ok, great
Thanks and Regards
