I don't think this would be a good idea. Most people are probably using USB flash drives for their boot devices and constantly writing to the device will wear it out early.
Sorry to stir this up so long later the latest posting, but I've been looking into this as well as potentially moving the system dataset onto the mirrored slog I plan to implement.
I was wondering if you attempted moving system dataset onto your boot device and if so what your experience with this was.
It will work
But the death of the flash drive is imminent
Mine was dead in 4 months
It will be ok on an ssd
But I have read that it is possible to lose your pool if the system dataset gets corrupted
Do not hold me to this
Might be wrong
But redundancy for the system dataset should be considered
It will work
Might be wrong
I plan to move to SSD if I were to do so, but I'd also ask how large was your flash drive. I'd think having a larger flash drive would also allow for better wear leveling, as 4 months sees ridiculously short.
The flash drive is an 8GB kingston dtse9 G2 as exact detail
I still have it
It sufferd an error
And while I was attempting to add redundancy to save me from reinstalling
It failed crashing the system
This question was asked at a time where there were no option in FreeNAS to do so.
Don't remember the exact version, but for several releases, you now have the option to choose what pool to put these datasets on from the "System-System Dataset" menu.
Been running it on boot pool since it got implemented and have had no issues. Boot pool is on a Intel G2 SSD though. :)
