I got hit with this as well. It means that on your replication destination system, the .system dataset is on the same pool as the replication target AND your are replicating into the root of that pool. There are 2 options:
1. use the GUI to move the system dataset to a different pool.
2. create a sub-dataset and replicate into that.
I also found that even after I moved my system dataset, there were still remnants left behind which continued to provide errors. I just completely wiped the pool and started over (using a sub-dataset).
Can you please provide the results of "zfs list" from teh destination system in code tags?
NAME USED AVAIL REFER MOUNTPOINT BUSINESS 1.17T 2.34T 136K /mnt/BUSINESS BUSINESS/.system 1.60G 2.34T 170M /mnt/BUSINESS/.system BUSINESS/.system/configs-d693e87545574e0bb5bd7bed67e6e6ce 512K 2.34T 96K /mnt/BUSINESS/.system/configs-d693e87545574e0bb5bd7bed67e6e6ce BUSINESS/.system/cores 12.8M 2.34T 8.06M /mnt/BUSINESS/.system/cores BUSINESS/.system/rrd-d693e87545574e0bb5bd7bed67e6e6ce 960K 2.34T 96K /mnt/BUSINESS/.system/rrd-d693e87545574e0bb5bd7bed67e6e6ce BUSINESS/.system/samba4 236M 2.34T 3.85M /mnt/BUSINESS/.system/samba4 BUSINESS/.system/syslog-d693e87545574e0bb5bd7bed67e6e6ce 183M 2.34T 39.7M /mnt/BUSINESS/.system/syslog-d693e87545574e0bb5bd7bed67e6e6ce BUSINESS/Backup 496K 2.34T 96K /mnt/BUSINESS/Backup BUSINESS/Backup/pfSense 248K 2.34T 96K /mnt/BUSINESS/Backup/pfSense BUSINESS/Shares 512G 2.34T 104K /mnt/BUSINESS/Shares BUSINESS/Shares/Compta 4.08G 2.34T 2.01G /mnt/BUSINESS/Shares/Compta BUSINESS/Shares/Direction 3.11G 2.34T 2.76G /mnt/BUSINESS/Shares/Direction BUSINESS/Shares/Divers 82.9M 2.34T 70.2M /mnt/BUSINESS/Shares/Divers BUSINESS/Shares/Employes 26.7G 2.34T 23.2G /mnt/BUSINESS/Shares/Employes BUSINESS/Shares/FTP 5.05M 2.34T 148K /mnt/BUSINESS/Shares/FTP BUSINESS/Shares/Partage 4.67G 2.34T 132K /mnt/BUSINESS/Shares/Partage BUSINESS/Shares/RPM 274M 2.34T 257M /mnt/BUSINESS/Shares/RPM BUSINESS/Shares/SRH 15.4G 2.34T 14.4G /mnt/BUSINESS/Shares/SRH BUSINESS/Shares/TT 444G 2.34T 416G /mnt/BUSINESS/Shares/TT BUSINESS/Shares/CPA 12.0G 2.34T 6.90G /mnt/BUSINESS/Shares/CPA BUSINESS/Shares/CPA-Partage 1.05G 2.34T 4.77M /mnt/BUSINESS/Shares/CPA-Partage BUSINESS/Virtualization 687G 2.34T 96K /mnt/BUSINESS/Virtualization BUSINESS/Virtualization/ISO 7.01G 2.34T 7.01G /mnt/BUSINESS/Virtualization/ISO BUSINESS/Virtualization/Machines 680G 2.34T 180G /mnt/BUSINESS/Virtualization/Machines Hm 5.60T 4.93T 264K /mnt/Hm Hm/.system 131M 4.93T 120M legacy Hm/.system/configs-f6da24756e2f4dee86c3a9c9fb75829f 7.69M 4.93T 7.69M legacy Hm/.system/cores 1.08M 4.93T 1.08M legacy Hm/.system/rrd-f6da24756e2f4dee86c3a9c9fb75829f 144K 4.93T 144K legacy Hm/.system/samba4 416K 4.93T 416K legacy Hm/.system/syslog-f6da24756e2f4dee86c3a9c9fb75829f 1.19M 4.93T 1.19M legacy Hm/Divers 67.8G 4.93T 67.8G /mnt/Hm/Divers Hm/Documents 2.67M 4.93T 132K /mnt/Hm/Documents Hm/Documents/owncloud 2.54M 4.93T 2.54M /mnt/Hm/Documents/owncloud Hm/Maisons 256K 4.93T 256K /mnt/Hm/Maisons Hm/Medias 3.57T 4.93T 132K /mnt/Hm/Medias Hm/Medias/Films 2.45T 4.93T 2.45T /mnt/Hm/Medias/Films Hm/Medias/Series 1.12T 4.93T 1.12T /mnt/Hm/Medias/Series Hm/Prisons 18.5G 4.93T 428K /mnt/Hm/Prisons Hm/Prisons/.warden-template-pluginjail--x64 449M 4.93T 449M /mnt/Hm/Prisons/.warden-template-pluginjail--x64 Hm/Prisons/.warden-template-pluginjail-9.2-x64 721M 4.93T 721M /mnt/Hm/Prisons/.warden-template-pluginjail-9.2-x64 Hm/Prisons/.warden-template-portjail-9.2-x64 1.58G 4.93T 1.58G /mnt/Hm/Prisons/.warden-template-portjail-9.2-x64 Hm/Prisons/couchpotato_1 369M 4.93T 1.06G /mnt/Hm/Prisons/couchpotato_1 Hm/Prisons/owncloud_1 446M 4.93T 1.14G /mnt/Hm/Prisons/owncloud_1 Hm/Prisons/plexmediaserver_1 14.2G 4.93T 14.9G /mnt/Hm/Prisons/plexmediaserver_1 Hm/Prisons/sickrage_1 689M 4.93T 1.35G /mnt/Hm/Prisons/sickrage_1 Hm/Prisons/transmission_1 130M 4.93T 579M /mnt/Hm/Prisons/transmission_1 Hm/TimeMachine 1.24T 4.93T 112K /mnt/Hm/TimeMachine Hm/TimeMachine/MacBookPro 568G 456G 568G /mnt/Hm/TimeMachine/MacBookPro Hm/TimeMachine/Mini 698G 326G 698G /mnt/Hm/TimeMachine/Mini Hm/Torrents 729G 4.93T 140K /mnt/Hm/Torrents Hm/Torrents/Fichiers 136K 4.93T 136K /mnt/Hm/Torrents/Fichiers Hm/Torrents/Telechargements 729G 4.93T 729G /mnt/Hm/Torrents/Telechargements freenas-boot 1.69G 5.52G 31K none freenas-boot/ROOT 1.63G 5.52G 25K none freenas-boot/ROOT/FreeNAS-9.3-STABLE-201505040117 3.46M 5.52G 496M / freenas-boot/ROOT/FreeNAS-9.3-STABLE-201505130355 4.01M 5.52G 511M / freenas-boot/ROOT/FreeNAS-9.3-STABLE-201506162331 8.47M 5.52G 513M / freenas-boot/ROOT/FreeNAS-9.3-STABLE-201506232120 36K 5.52G 516M / freenas-boot/ROOT/FreeNAS-9.3-STABLE-201506292332 10.2M 5.52G 519M / freenas-boot/ROOT/FreeNAS-9.3-STABLE-201509022158 8.86M 5.52G 520M / freenas-boot/ROOT/FreeNAS-9.3-STABLE-201509282017 1.59G 5.52G 524M / freenas-boot/ROOT/default 3.85M 5.52G 471M legacy freenas-boot/grub 54.2M 5.52G 6.79M legacy
And to answer your question, no, you can't just delete it. There is risk.
I just figured this issue out a few days ago. Are you trying to backup TO the Business dataset or Business is the dataset you want to replicate to another? Is the backup located on the same machine or a different one?
Business\Backup should be your replication target but we need to know what dataset you are trying to replicate.
If you are sure that the system dataset is somewhere else then you can delete it. OTOH, are you sure it isn't part of the Push dataset? The data came from somewhere.
This happened to me and I triple checked before deleting it.
Yes there is a workaround. I gave it to you in my first post. Create a dataset on pull and replicate into that instead of the root. That's what I did.Well yeah for sure it could most definitely come from the replicated data!
But what then?
Every time I replicate it's going to create again a replicated system dataset, and then whine about the fact that there's a system dataset on target?
Is there a workaround this?
Will you post their numbers so we can follow up?That means I have to file 2 (more) bugs
