SOLVED FreeNAS 9.2.5.1 fails on pci1 ACPI pcib7
Mallo
I was following the guide for the AD file and folder permissions here but I was using FreeNas 9.3.1. I was able to get 9.3.1 installed with no issues and start the configuration and get a lot configured except when it came to setting up the Windows ACL.
I then decided to attempt installing using the exact version of FreeNAS that is outlined in the guide. I reset the raid 1 array and wiped all partitions on the flash drive to give myself a true vanilla starting point. That is where I get stuck.
The system I am installing on is a Dell Poweredge 1950 server. Dual Intel Xeon Processors with 8GB of RAM, and a PERC 5i raid card.
Any assistance on getting FreeNAS 9.2.1.5 installed or if there is another guide for 9.3.1 to setup the Windows ACL's, I would appreciate any insight.
Screenshot of the frozen screen attached.
SweetAndLow
Sweet'NASty
Just use 9.3.1 and test/play with acl to understand how they work. Just blindly following a guide won't give you something that works. Your setup will be slightly different so best to just know how it works. Also from the setup perspective is exactly the same in 9.3 as 9.2.1.x
