Freenas 9.1 - RC Observations
Yatti420
Hello everybody..
Been playing with freenas 9.1.0-RC build.. Running really good.. Using a USB 3.0 Flash drive.. Nothing special but does work and boot with no issues..
GUI#1
Noticed a few things not sure if really a bug or issue for future releases.. The report graphs for system directories (root/etc/mnt...) are broken after first reboot.. Probably not a big deal as they wont be there i'm assuming upon official release?
GUI#2
I removed all (and disabled autotune since I had low ram - Shouldn't be on) sysctls carried over from old config and Removing tunables in the GUI is very slow for me.. Taking 5x longer then removing a sysctls..
Jail Storage Mounts
The only weird thing I can't figure out (which I hope isn't a rtfm question) is why certain jail directories (pictures) aren't "auto mounting" upon startup.. I can mount the offending directory easily by clicking it then checking mount.. Is there limitations with pathnames (no spaces etc?) Only mount certain amount of directories? Minidlna (with media_dir=) and transmission work no probs so far.. If I am downloading something I change the owner/perms manually before moving the files into perm storage..
Going to look into this output and dig into logs in a bit.. My NAS sits on .125 and jail on .126.. Jail is standard with VIMAGE/NAT disabled..
Jul 25 22:30:01 NAS last message repeated 2 times
Jul 25 22:30:01 NAS manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/sipcalc alc0
Jul 25 22:30:01 NAS manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/sipcalc 192.168.0.126
Jul 25 22:30:02 NAS manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/sipcalc 192.168.0.127/32
Jul 25 22:34:56 NAS manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list  -v
Jul 25 22:34:56 NAS manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/sipcalc alc0
Jul 25 22:34:56 NAS manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/sipcalc 192.168.0.126
Jul 25 22:34:56 NAS manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/sipcalc 192.168.0.127/32
Stop refresh
Thanks!
Yatti420
I accessed jails from shell using "jexec 1 /bin/tcsh" seems to work fine..
Yatti420
I fixed my jail storage issue.. I guess no spaces are permitted in the path.. Keep it simple seems to work... jail mounts working after every reboot..
Nope. In CLI world spaces in filenames are the bane of many admins....
