Ajuda. Transmission
galera me ajuda nao sei como configurar ... nao inicia o torrnet eu digito o ip:9091 e nao abre o torrent e ao abrir o log ficar assim
Oct 8 05:55:01 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v Oct 8 05:55:02 freenas last message repeated 2 times Oct 8 05:55:02 freenas manage.py: [py.warnings:193] /usr/local/lib/python2.7/site-packages/django/http/request.py:193: DeprecationW arning: HttpRequest.raw_post_data has been deprecated. Use HttpRequest.body instead. warnings.warn('HttpRequest.raw_post_data has been deprecated. Use HttpRequest.body instead.', DeprecationWarning) Oct 8 05:55:02 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v Oct 8 05:55:25 freenas notifier: No matching processes were found Oct 8 05:55:25 freenas notifier: Performing sanity check on Samba configuration: OK Oct 8 05:55:25 freenas manage.py: [py.warnings:409] /usr/local/lib/python2.7/site-packages/django/core/management/__init__.py:409: DeprecationWarning: The 'setup_environ' function is deprecated, you likely need to update your 'manage.py'; please see the Django 1. 4 release notes (https://docs.djangoproject.com/en/dev/releases/1.4/). DeprecationWarning) Oct 8 05:55:47 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v Oct 8 05:56:04 freenas last message repeated 2 times Oct 8 06:03:51 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v Oct 8 06:23:25 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v
GabrielPorto
Cara o IP que voce tem que conectar é o do transmission.
Entra no nas, no caso da sua imagem é http://192.168.1.64/
Loga com o usuario e senha que voce cadastro ( caso seja o 1º loguin voce cadastra uma senha)
Agora entra nos Jaill
index.php
E olha qual o IP que ele esta usando
No meu caso o transmission ta usando o 192.168.0.212
para acessar o tranmission vc tem q entra com a porta 9091
entao fica assim http://X.X.X.X:9091
onde X é o endereco de IP dele
