FreeNAS 9.1 not detecting a drive
molko
As per title really.
FreeNAS 9.1 is up an running. I can browse to the GUI and SSH on to the box.
However from the GUI it appears no HDD are recognised ! I have have installed 4 x 3TB disks
dmesg | grep -e ada
returns nothing from the command line.
Please help.......Any advice would be be much appreciated
molko
As you can see no disks are detected...
molko
<CODE>[root@freenas] ~# camcontrol devlist
< USB DISK 2.0 PMAP> at scbus0 target 0 lun 0 (pass0,da0) </CODE>
molko
pirateghost
Unintelligible Geek
Without any hardware information it is hard to just guess what the problem is, but I would say you have an unsupported drive controller...
molko
Thanks for the response.
The PC is a regular HP Microserver Gen8 G2020T with 4 x 3TB (3TB Red SATA 6Gb/s 64MB 3.5" Hard Drive) Western Digital drives.
When I reboot the Micoserver and use the "HP Smart Storage Administrator" then the drives are recongised and I'm able to create a RAID array should I wish - I haven't because I thought ZFS used the disks in non-RAID
What other information could I give you ?
Thanks
molko
I should point out the the HDD are brand new and have not yet been formatted - they are straight out of the box
pirateghost
Unintelligible Geek
But what are they plugged into?
More information if you want help....
molko
Plugged straight into the non-hot-swappable disk caddies - I'd imagine its SATA behind the scenes. I guess becuase they can be identified by "HP Smart Storage Administrator" it means they are are seated properly/getting power etc...
I am complete newcomer to FreeNAS, so as you can imagine I have very little experience, but am very keen to learn.
I meant is there any 'commands' to provide you guys with information to narrow down the issue.
Thanks
pirateghost
Unintelligible Geek
I will ask again, please list your hardware configuration. What kind of server is this?
molko
Sorry, I thought I had
Product Description
    HP ProLiant MicroServer Gen8 Base - P G2020T 2.5 GHz - Monitor : none.
Type
    Server
Form Factor
    Ultra micro tower
Localisation
    Europe
Server Scalability
    1-way
Processor
    1 x Intel Pentium G2020T / 2.5 GHz ( Dual-Core )
Cache Memory
    2 MB L3 Cache
Cache Per Processor
    2 MB
RAM
    2 GB (installed) / 16 GB (max) - DDR3 SDRAM - ECC - PC3-12800
Storage Controller
    SATA ( SATA 6Gb/s ) ( HP Dynamic Smart Array B120i )
Hard Drive
    No HDD
Monitor
    None.
Graphics Controller
    Matrox G200
Networking
    Gigabit LAN
Power
    AC 120/230 V ( 50/60 Hz )
OS Provided
    No operating system
Dimensions (WxDxH)
    22.97 cm x 24.51 cm x 23.24 cm
Weight
    6.8 kg
Manufacturer Warranty
    1 year warranty
CPU
Number of Cores
    Dual-Core
CPU Qty
Max CPU Qty
CPU Upgradability
    Upgradable
Chipset Type
    Intel C204
Installed Size
    L3 Cache - 2 MB
Cache Per Processor
    2 MB
Installed Size
    2 GB / 16 GB (max)
Technology
    DDR3 SDRAM - ECC
Memory Specification Compliance
    PC3-12800
Form Factor
    DIMM 240-pin
Features
    Unbuffered
Configuration Features
    1 x 2 GB
Type
    1 x SATA - integrated
Controller Interface Type
    SATA 6Gb/s
Storage Controller Name
Channel Qty
    5
RAID Level
    RAID 0, RAID 1, RAID 10
molko
Hi
I've sussed it. The HP RAID was taking precedence over AHCI. So i have disabled the RAID stuff and enabled AHCI then rebooted - I can now see all 4 x 3TB disks + 1 SSD in the freeNAS GUI.
Thats sounds about right to me......What do you reckon
Thanks for your help..
And don't do ZFS with 2GB of RAM.. 8GB minimum for ZFS or you can kiss your data goodbye someday...
