Autotune is for systems with >8GB of RAM if I remember correctly. I think it says that in the manual. I always have 16GB minimum so I always check it. Autotune increases a couple of settings to use more memory to improve performance. In your case, you might not be able to boot anymore if you enabled it.
If you are running ZFS with only 2GB of RAM you are really taking a risk of kernel panics and the resulting loss of data from an unmountable zpool. The 6GB of RAM requirement to use ZFS is no joke and plenty of people thought they could get away with less and lost their entire zpool.
